crf59 Posted September 26, 2024 Share #1 Posted September 26, 2024 Advertisement (gone after registration) Hi folks, I've had my SL3 for 3 months and absolutely love it. Best of all worlds in my opinion. One issue I discovered recently is battery drain when the camera is off. I don't mean in sleep mode, I mean fully off. I had used the camera 3 weeks ago, put it away and today discovered the battery was completely drained. When put away the battery was >90%. Is there a background process going on? Has anyone else experienced this? I've had this problem with other brands I own, but not for any of my other Leicas (M11, SL2, SL2-S, M10-P). Link to post Share on other sites More sharing options...
Advertisement Posted September 26, 2024 Posted September 26, 2024 Hi crf59, Take a look here SL3 Battery Drain When Off . I'm sure you'll find what you were looking for!
Ken Abrahams Posted September 27, 2024 Share #2 Posted September 27, 2024 I was going to suggest that the GPS may have caused the drain but thought I would leave the replies to other members here. It's worth a check to see how the GPS in Fotos is configured as this is the only thing "still on" when you shut down the camera. I have had a couple of glitches with SL3 and SL2S cameras however all is working well now. One camera when switching off did not go off all the way and instead a feint glow in the top screen after the mechanical off was activated (SL2S) The SL3 also had a glitch at first but that has gone now. I do however watch for the top screen after shutting down cameras and if screen remains glowing I will pull the battery. I have both SL3 and SL2s configured for Fotos app and when I am out shooting with both cameras they are connected to Fotos and the GPS is flawless now. The SL2S seemed to settle into its configuration in Fotos "Always on" setting. 1 Link to post Share on other sites More sharing options...
GFW2-SCUSA Posted September 27, 2024 Share #3 Posted September 27, 2024 I have the phantom battery drain on my SL2 also. I was wondering if popping the battery out when leaving it for a while would be a solution. Then I wondered if there is some need for the battery to be in for some reason. I wasn't thinking of taking it all the way out, just the first pop. Any thoughts?? Link to post Share on other sites More sharing options...
KenTanaka Posted September 27, 2024 Share #4 Posted September 27, 2024 Disabling all connectivity (WiFi, etc.) should greatly curtail the battery drain. The radios in cameras can draw considerable power particularly when they detect weak signal. I do no use any RF connectivity in my Leica cameras and have not experienced the steeping-ish idle drain with my SL3, although I can say that I’ve experienced similar drain with other cameras when I’ve left the radios active. Hope this helps. Link to post Share on other sites More sharing options...
crf59 Posted September 27, 2024 Author Share #5 Posted September 27, 2024 I'm going to try checking settings in the camera for GPS/WiFi. I'm also experimenting with swapping batteries and seeing how long it takes to drain to 50%. We'll see. Otherwise I love the SL3. The IQ from my M11 is great and I thought would be unbeatable. But honestly the SL3 has all that IQ and more. Link to post Share on other sites More sharing options...
T25UFO Posted September 27, 2024 Share #6 Posted September 27, 2024 As advised in another thread: > Fotos > Connectivity. You then have three options. > Performance mode: bluetooth and wi-fi permanently activated. Most power hungry, shortest battery life. > Eco mode: bluetooth permanently activated, but wi-fi enabled only during file transfer. Some battery drain. > Off (aka airplane mode): all radio frequency connections deactivated. Longest battery life. Link to post Share on other sites More sharing options...
billhart Posted October 9, 2024 Share #7 Posted October 9, 2024 Advertisement (gone after registration) I too used my SL3 about a month ago and when I turned it on the battery was completely drained. The battery is the new one I got with the SL3. I have the new firmware and I don't use the GPS (Fotos). Can I pop my battery out (first click only) and will that cause the settings to erase? Link to post Share on other sites More sharing options...
