double exposure
underground
I have a silly question on double exposure. My SLR allows me to hold down the rewind
button in and cock my shutter without advancing the film to take two exposures on one
negative.
This does not work with my M7, Will this method work on earlier M bodies?
THANKS!
Don't quote me on this, but ...
I thought it was possible to flip the rewind lever down, cock the shutter without actually advancing the film, and then flip the rewind lever up again to make double exposures.
I haven't actually tried it, but I thought it was possible.
Anyone with actual real-world experience?
Not on a M3, I just tried it. The rewind latch inside the camera disengages the moment the wind/film advance lever is moved.
But there is a way to do in on older M's like the M2/3 and the MP. Watch how much the rewind knob moves, how many times it goes around, when advancing the film. Mine goes around .75 of a full turn. So if you set the rewind switch and turn the film back 3/4 of a turn and then advance it you should be really close to being at the same frame point. It's not perfect but double exposure aren't supposed to be perfect.
Its probably stating the blee..... obvious to say so, but the amount the rewind knob (actually the red dots in the centre of the knob on my M3) revolves when the film is wound will vary depending on the amount of film left in the cassette, the less film there is the smaller the effective diameter so the more the dots will revolve as one frame of film is drawn out, so you will need to check the actual amount for the frame you are double exposing.
Gerry.
Doesn't work.
I'v just tried it on my LTM IIIc .. works no problem ..
release film advance lock lever to position R.
rewind film and observe black dot on shutter release button at 1 full rotation
move lock lever back to A position
wind on film by 1 frame
try it with an old roll of film.with slow speed setting at position "T"
you can then ink mark a position on the film and see if it advances back to the exact position before rewind.
ahh fun and games on a monday afternoon ;)
Noel
Tried on the MP, jeeping the r lever down and cocking the shutter, only very little movement of the rewinds red dots. Feels rough, don't know if it can harm the cam, I'm going to consult my Leica doctor about it but looking foreward to see what the results are going to be.
Feels nice to fool this most rugged camera;-)
