Greenhilltony Posted August 21, 2024 Share #1 Posted August 21, 2024 Advertisement (gone after registration) I recently acquired an M2. The frame counter dial had a moderate tightness IMO but I hadn’t had any experience with an M2. It could be easily rotated by a few clicks if my finger tips happened to slide over it when I picked up the camera. Later I sent it to CLA because the shutter got sticky if it had been cocked for a while. When it returned I found the counter dial became very tight that I had to use two fingers and nails to catch the dial and rotate it. It would no longer be easily rotated by finger sliding over it. I think it’s great so I don’t need to worry about touching it and mess up the counter anymore. But just in case I want to ask the experienced users that if it is how it supposed to be for the M2. Cheers! Link to post Share on other sites More sharing options...
Advertisement Posted August 21, 2024 Posted August 21, 2024 Hi Greenhilltony, Take a look here M2 frame counter dial tightness problem. I'm sure you'll find what you were looking for!
TomB_tx Posted August 21, 2024 Share #2 Posted August 21, 2024 My M2 is medium-tight: still move with one finger, but positive clicks. Link to post Share on other sites More sharing options...
250swb Posted August 21, 2024 Share #3 Posted August 21, 2024 It shouldn’t rotate just by rubbing your finger over it or it will forever show the wrong number of frames you’ve shot. It should be tight given you only want to adjust it once for every film. Link to post Share on other sites More sharing options...
Greenhilltony Posted August 21, 2024 Author Share #4 Posted August 21, 2024 1 hour ago, 250swb said: It should be tight given you only want to adjust it once for every film. That’s what I thought. I once met a friend who had a repainted M2 with a loosen counter dial, and it troubles him a lot Link to post Share on other sites More sharing options...
colint544 Posted August 23, 2024 Share #5 Posted August 23, 2024 If it's any help/consolation, I also have an M2, and the shot counter dial is tight. Camera was serviced by Kanto, and when it came back it was still the same. Takes two fingers and a firm grip to turn. Figure it's a very old camera, and I've just got used to it. I'd rather it was a bit tight than too loose. 1 Link to post Share on other sites More sharing options...
Mute-on Posted August 23, 2024 Share #6 Posted August 23, 2024 Mine is also pretty tight. Generally requires a finger nail to help it around. Having said that, I usually don’t bother and just ignore it since I always have extra film on hand. If it was my last roll, I would be paying attention … 1 Link to post Share on other sites More sharing options...
