Jonathan Levin Posted August 17, 2024 Share #1 Posted August 17, 2024 (edited) Advertisement (gone after registration) Hello. today I was shooting some sky scenes. I noticed that whenever my shutter speed went faster than 6000s or above, there is no shutter sound. I have my shutter settings set to hybrid. At first I thought the camera was not capturing images, but a quick playback showed the images. Is this normal? Edited August 17, 2024 by Jonathan Levin Link to post Share on other sites More sharing options...
Advertisement Posted August 17, 2024 Posted August 17, 2024 Hi Jonathan Levin, Take a look here No shutter sound at 6000sec and above??? . I'm sure you'll find what you were looking for!
Ken Abrahams Posted August 17, 2024 Share #2 Posted August 17, 2024 (edited) Usually on hybrid setting the camera will shift to electronic shutter at 1/4000 which has no sound. There is a known issue with the electronic shutter not being able to exceed 1/8000 when using aperture priority and or Program mode. Any exposure thats over 1/8000 will be clipped because of this fault so shooting will need to shift to S mode to effect a correct exposure. So you have found the shutter is changing at 1/6000? Edited August 17, 2024 by Ken Abrahams 1 Link to post Share on other sites More sharing options...
jaapv Posted August 18, 2024 Share #3 Posted August 18, 2024 A mechanical shutter makes a sound, an electronic one is silent Clearly 1/6000th is when the ES kicks in. So completely normal. Some camera brands offer a fake click sound. 1 Link to post Share on other sites More sharing options...
SrMi Posted August 18, 2024 Share #4 Posted August 18, 2024 2 hours ago, Jonathan Levin said: Hello. today I was shooting some sky scenes. I noticed that whenever my shutter speed went faster than 6000s or above, there is no shutter sound. I have my shutter settings set to hybrid. At first I thought the camera was not capturing images, but a quick playback showed the images. Is this normal? Which camera? 1 Link to post Share on other sites More sharing options...
Jonathan Levin Posted August 18, 2024 Author Share #5 Posted August 18, 2024 Thank you for that. Camera= SL3. Manual mode. Thanks for clearing that up! Link to post Share on other sites More sharing options...
SrMi Posted August 18, 2024 Share #6 Posted August 18, 2024 On my SL3 in M mode, hybrid shutter type, 1/5000 and higher, the shutter is silent (electronic shutter). 1 Link to post Share on other sites More sharing options...
Ken Abrahams Posted August 18, 2024 Share #7 Posted August 18, 2024 Advertisement (gone after registration) The shutter specifications for SL3 from Leica say Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/401832-no-shutter-sound-at-6000sec-and-above/?do=findComment&comment=5485384'>More sharing options...
SrMi Posted August 18, 2024 Share #8 Posted August 18, 2024 12 minutes ago, Ken Abrahams said: The shutter specifications for SL3 from Leica say Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Yes, the maximum shutter speed with the mechanical shutter type is 1/8000. The manual does not say at what shutter speed the hybrid shutter type switches to the electronic shutter. I would expect it to happen at the maximum possible mechanical shutter speed, but that is not the case. 1 Link to post Share on other sites More sharing options...
Ken Abrahams Posted August 18, 2024 Share #9 Posted August 18, 2024 32 minutes ago, SrMi said: Yes, the maximum shutter speed with the mechanical shutter type is 1/8000. The manual does not say at what shutter speed the hybrid shutter type switches to the electronic shutter. I would expect it to happen at the maximum possible mechanical shutter speed, but that is not the case. Yes, My electric shutter engages at 1/4000 which is what I typed originally but then changed it to 8000 for some reason. So after checking, mine is - up to 1/4000 mechanical over 4000 electric Link to post Share on other sites More sharing options...
Stuart Richardson Posted August 19, 2024 Share #10 Posted August 19, 2024 Perhaps using it repeatedly at maximum speed stresses the shutter assembly, so they engage the electric shutter a bit early in hybrid mode? It is an interesting occurrence. 1 Link to post Share on other sites More sharing options...
hdmesa Posted August 19, 2024 Share #11 Posted August 19, 2024 10 hours ago, Stuart Richardson said: Perhaps using it repeatedly at maximum speed stresses the shutter assembly, so they engage the electric shutter a bit early in hybrid mode? It is an interesting occurrence. And/or to avoid excessive shutter shock with long lenses perhaps. Link to post Share on other sites More sharing options...
hdmesa Posted August 20, 2024 Share #12 Posted August 20, 2024 On 8/17/2024 at 10:20 PM, Ken Abrahams said: Yes, My electric shutter engages at 1/4000 which is what I typed originally but then changed it to 8000 for some reason. So after checking, mine is - up to 1/4000 mechanical over 4000 electric In A mode, mine uses ES for 1/4000 sec. and above. Mechanical is only below 1/4000 sec. Perhaps 1/4000 sec. itself can go either way depending on main shooting mode and other settings. 1 Link to post Share on other sites More sharing options...
Ken Abrahams Posted August 21, 2024 Share #13 Posted August 21, 2024 I have all Leica SL iterations and 1/4000 change to ES is the same for all of them. best Ken 1 Link to post Share on other sites More sharing options...
