dlaundon Posted July 28, 2024 Share #1 Â Posted July 28, 2024 Advertisement (gone after registration) Can someone help me please. I had removed the battery from my Leicaflex SL, and stupidly screwed the battery cover back, obviously too far. Now I can't undo it because it keeps cross threading. It starts off ok but then tightens up and will NOT budge. Is there any way that I can remove the base plate to try and sort this problem or can anyone suggest anything ? Link to post Share on other sites More sharing options...
Advertisement Posted July 28, 2024 Posted July 28, 2024 Hi dlaundon, Take a look here Leicaflex SL - Cross threaded battery door. I'm sure you'll find what you were looking for!
frame-it Posted July 28, 2024 Share #2  Posted July 28, 2024 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  ' data-webShareUrl='https://www.l-camera-forum.com/topic/399821-leicaflex-sl-cross-threaded-battery-door/?do=findComment&comment=5449793'>More sharing options...
frame-it Posted July 28, 2024 Share #3 Â Posted July 28, 2024 59 minutes ago, dlaundon said: Can someone help me please. I had removed the battery from my Leicaflex SL, and stupidly screwed the battery cover back, obviously too far. Now I can't undo it because it keeps cross threading. It starts off ok but then tightens up and will NOT budge. Is there any way that I can remove the base plate to try and sort this problem or can anyone suggest anything ? Â Link to post Share on other sites More sharing options...
jaapv Posted July 28, 2024 Share #4 Â Posted July 28, 2024 Try to remove it using a Flexclamp wrench. Link to post Share on other sites More sharing options...
250swb Posted July 29, 2024 Share #5 Â Posted July 29, 2024 On 7/28/2024 at 2:35 PM, dlaundon said: Â Is there any way that I can remove the base plate to try and sort this problem or can anyone suggest anything ? Are there any screws? Link to post Share on other sites More sharing options...
TomB_tx Posted July 29, 2024 Share #6 Â Posted July 29, 2024 On 7/28/2024 at 8:35 AM, dlaundon said: Can someone help me please. I had removed the battery from my Leicaflex SL, and stupidly screwed the battery cover back, obviously too far. Now I can't undo it because it keeps cross threading. It starts off ok but then tightens up and will NOT budge. Is there any way that I can remove the base plate to try and sort this problem or can anyone suggest anything ? That happened to me once: Took a short length of dowel (about 1/2" dia.) and put a piece of double-sided tape on the end. Stuck it on on the cap and used the dowel to keep it aligned square while rotating an pulling gently to find the thread start. Came off easily. Link to post Share on other sites More sharing options...
