ChewbeeDoo Posted June 25, 2024 Share #1 Posted June 25, 2024 (edited) Advertisement (gone after registration) Greetings to all, I am the new happy owner of a used M240, my first Leica after years of desire. Yesterday, I notice a very strange behaviour. I used Auto ISO, A priority. I took 10 or 15 photos and noticed this: Each photo information was exposed with an exposure compensation which was not the value seated (-0,7) It can be -1.7 it can be something else ... I turned off Auto ISO ==> no impact. At the end I suspected bracketing, which has few options (mode, number of frames, on/off) I had to turn off the two lines to get rid of the strange behaviour .. And other way to say it is that, it was taking only one picture but with a different exposition value !! Did one of your ver notices this behaviour ? And no I checked I did not inadvertently touch the wheel Many thanks and kind regards Edited June 25, 2024 by ChewbeeDoo not touched the wheel Link to post Share on other sites More sharing options...
Advertisement Posted June 25, 2024 Posted June 25, 2024 Hi ChewbeeDoo, Take a look here Bug ? Awkward Exposure behaviour. I'm sure you'll find what you were looking for!
jaapv Posted June 25, 2024 Share #2 Posted June 25, 2024 You may be a inadvertently turning the the thumb wheel. 1 Link to post Share on other sites More sharing options...
Viv Posted June 25, 2024 Share #3 Posted June 25, 2024 8 minutes ago, jaapv said: You may be a inadvertently turning the the thumb wheel. Most likely. 1 Link to post Share on other sites More sharing options...
Jean-Michel Posted June 25, 2024 Share #4 Posted June 25, 2024 5 hours ago, Viv said: Most likely. Fool-proof method to avoid moving the thumb wheel inadvertently: add Steve Barnett's " Thumbie " to the camera. The thumb wheel remain easily accessible but about impossible to turn by mistake. Link to post Share on other sites More sharing options...
dugby Posted June 26, 2024 Share #5 Posted June 26, 2024 16 hours ago, ChewbeeDoo said: Greetings to all, I am the new happy owner of a used M240, my first Leica after years of desire. Yesterday, I notice a very strange behaviour. I used Auto ISO, A priority. I took 10 or 15 photos and noticed this: Each photo information was exposed with an exposure compensation which was not the value seated (-0,7) It can be -1.7 it can be something else ... I turned off Auto ISO ==> no impact. At the end I suspected bracketing, which has few options (mode, number of frames, on/off) I had to turn off the two lines to get rid of the strange behaviour .. And other way to say it is that, it was taking only one picture but with a different exposition value !! Did one of your ver notices this behaviour ? And no I checked I did not inadvertently touch the wheel Many thanks and kind regards Over the support life of the M240 there were ten publicly released versions of firmware, What firmware version is in your M240 ? Link to post Share on other sites More sharing options...
ChewbeeDoo Posted June 27, 2024 Author Share #6 Posted June 27, 2024 (edited) On 6/26/2024 at 3:28 AM, dugby said: Over the support life of the M240 there were ten publicly released versions of firmware, What firmware version is in your M240 ? Hello, Thank you for your message. The latest version I guess ==> 2.1.0.0 I solved the issue I guess, It it odd as behaviour and not a bug (hardly a feature tho If you have expo compensation set to -0.7 your setup are like in the menu (3 frames) and you press the trigger ==> you will get one pic at -1.7, if you click again ==> -0.7, and again , one pic at +0.3 So the bracketing is manual but effective, despite the last line set to "Off", which only defines if the camera takes 1 or the N frames automatically So you have to put the first line to zero Thanks to all for your help Edited June 27, 2024 by ChewbeeDoo SOLVED 1 Link to post Share on other sites More sharing options...
