Marc-2024 Posted April 24, 2024 Share #1 Posted April 24, 2024 Advertisement (gone after registration) I’ve recently purchased a new TL. Long forgotten on the back shelf of a camera store. I was drawn to the simplicity of the design and easy-to-use interface. I’m sure this has been covered before. What non-Leica AF L mount lenses are compatible with the TLs? I’ve tried the Pan 20-60mm and AF did not work. Any guidance would be greatly appreciated. Link to post Share on other sites More sharing options...
Advertisement Posted April 24, 2024 Posted April 24, 2024 Hi Marc-2024, Take a look here AF Lenses for a Leica TL. I'm sure you'll find what you were looking for!
jaapv Posted April 24, 2024 Share #2 Posted April 24, 2024 A fine camera, congratulations. It should work. All L and TL lenses are compatible so consult your camera store. It is probably a setting or an update. Link to post Share on other sites More sharing options...
Marc-2024 Posted April 24, 2024 Author Share #3 Posted April 24, 2024 I did find a firmware update for the Pan 20-60mm. Not sure if the shop, will let me update it. I also didn't try the other 2 lenses to see if they would work. I’ll keep you posted. Link to post Share on other sites More sharing options...
dpitt Posted April 24, 2024 Share #4 Posted April 24, 2024 AF on the 20-60 should work on the TL. I use it on my TL2 from time to time. Link to post Share on other sites More sharing options...
AdjusterBrett Posted April 24, 2024 Share #5 Posted April 24, 2024 5 hours ago, dpitt said: AF on the 20-60 should work on the TL. I use it on my TL2 from time to time. Ditto for me - in fact, all my sigs work, and all my Panasonics work as well... Sig DGDN 105/2.8, 85/1.4, 100-400, pana 50/1.8, 20-60/1.8 in current rotation, 105/1.4, 15-35/f4, and a couple others all worked as well. I have tried some of the sig DCDNs too - but having two L mount full frames - plunking down he money on an APSC only lens is an uphill battle (although NOTHING has ever looked as stupid as the 105/1.4 on the TL2)... The thing with the TL and TL2 is that you have to make sure you understand the menu - otherwise it will not AF... Still fiddle when changing from the Visoflex and vintage to a native lens. Link to post Share on other sites More sharing options...
Marc-2024 Posted April 28, 2024 Author Share #6 Posted April 28, 2024 (edited) Update: I had the setting incorrectly set up. The pan 20-60 works great. Thank you all for your help. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited April 28, 2024 by Marc-2024 4 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/393376-af-lenses-for-a-leica-tl/?do=findComment&comment=5224209'>More sharing options...
