01maciel Posted March 25, 2024 Share #1 Posted March 25, 2024 (edited) Advertisement (gone after registration) I recently bought an old Helios 44 2/58 LTM only to find that it won't focus on the M10 with any of my LTM adapters. A quick internet search revealed the fact that the Russian LTM thread is not compatible with the Leitz thread. The lens can only be used with another LTM->M42->M adapter but not coupled with the rangefinder. Why is that? Weird, after the Russians took the patents with them after WWII, they could have stayed with the standard valid at that time but they didn't. Now my question: are there any more of these LTM problems with the old Russian lenses? Edited March 25, 2024 by 01maciel Link to post Share on other sites More sharing options...
Advertisement Posted March 25, 2024 Posted March 25, 2024 Hi 01maciel, Take a look here LTM (ЛТМ) ≠ Leitz LTM . I'm sure you'll find what you were looking for!
Ecar Posted March 25, 2024 Share #2 Posted March 25, 2024 13 minutes ago, 01maciel said: Now my question: are there any more of these LTM problems with the old Russian lenses? In short, yes. As a general rule, FSU Zenit SLR lenses in LTM mount won't play nicely with the rangefinder. The register (flange distance to film) was different - and so was sometimes the thread pitch. FSU lenses designed for rangefinder cameras (e.g., J-3, J-8, I-22, etc.) suffer from similar issues, but to a much lesser degree and can usually be satisfactorily adjusted. 1 Link to post Share on other sites More sharing options...
spydrxx Posted March 25, 2024 Share #3 Posted March 25, 2024 A bunch of these were for early SLRs. 1 Link to post Share on other sites More sharing options...
earleygallery Posted March 25, 2024 Share #4 Posted March 25, 2024 As above I think you have a 39mm thread SLR lens for the early Zenit cameras, so it won't work with any adaptor on a Leica. Lenses for the Russian thread mount rangefinders do work on Leica's. 1 Link to post Share on other sites More sharing options...
UliWer Posted March 25, 2024 Share #5 Posted March 25, 2024 vor 1 Stunde schrieb 01maciel: Helios 44 2/58 LTM I fear it was only called „LTM“ by a salesman. „LTM“ is sort of internet slang for „ Leica M39 threadmount“, but the first version of the Zenit SLR also had a M39 mount before they went to apply the universal M42 mount. If you find out for which flange-to-film distance the lens was made and if you happen to own old Visoflex parts you might be able to construct your own adapter combining some of them. Link to post Share on other sites More sharing options...
earleygallery Posted March 25, 2024 Share #6 Posted March 25, 2024 Or buy a Zenit 3m body. https://camerapedia.fandom.com/wiki/Zenit_3M 1 Link to post Share on other sites More sharing options...
Ecar Posted March 25, 2024 Share #7 Posted March 25, 2024 Advertisement (gone after registration) Or use it with LV/EVF. Or have it converted. Link to post Share on other sites More sharing options...
Carlos cruz Posted March 25, 2024 Share #8 Posted March 25, 2024 13 minutes ago, Al Brown said: Or buy the 17 blades Biotar 5.8cm in black paint and a M42-M adapter. You will still not be able to use RF, but at least you will have a piece of history, the very lens Helios 44 was formed upon (presumably another Taylor, Taylor & Hobson, now Cooke based design, first produced before the war in 8 aperture blades version and available in 17 blades version from '46-'52). I love mine but sadly cannot get it converted - Skyllaney said they do not have the tools for the challenge. I recently bought one, after dismantling it I came to conclusion that the exa version is easier to convert, its small size makes it easier to fit in old helicoid. You can always get shoten adapter with rf confirmation. Link to post Share on other sites More sharing options...
Ecar Posted March 25, 2024 Share #9 Posted March 25, 2024 14 minutes ago, Al Brown said: Apparently no, Shoten M42-M adapters ONLY work properly with exactly 50mm lenses I was told. This one is 58mm... That's correct. 1 Link to post Share on other sites More sharing options...
Ecar Posted March 25, 2024 Share #10 Posted March 25, 2024 However, I suspect Shoten might at some point come up with adapters for other popular SLR F/L such as 55 and 58mm. Link to post Share on other sites More sharing options...
01maciel Posted March 26, 2024 Author Share #11 Posted March 26, 2024 Thanks for all your comments and advice. I ordered a Lens Mount Adapter ring, M39 --> M42 (39 mm – 42 mm thread) from Amazon. It's actually a mess since I use two adapter for this lens. First tests with the EVF have shown that focussing isn't a problem anymore. Some photos can be expected very soon 😄. 1 Link to post Share on other sites More sharing options...
01maciel Posted March 26, 2024 Author Share #12 Posted March 26, 2024 He didn't like the lens at all. But at least he sat there calmly for the photo, albeit annoyed. Incidentally, he is the only model in the wider area that doesn't do it for money. He only takes treats. M10 + Helios-44 LTM SLR Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/391630-ltm-%D0%BB%D1%82%D0%BC-%E2%89%A0-leitz-ltm/?do=findComment&comment=5136499'>More sharing options...
zeitz Posted March 26, 2024 Share #13 Posted March 26, 2024 23 hours ago, UliWer said: „LTM“ is sort of internet slang for „ Leica M39 threadmount“, LTM is NOT M39. LTM is 39mm diameter by 26 threads per inch (tpi). LTM should be referred to as L39. M39 is 39mm diameter with a metric pitch. There are coarse and several fine metric pitches that are part of the metric M39 DIN spec. Leica lenses, ignoring Visoflex lenses, are also 28.8 mm from the rear lens flange to the focal plane, called registration. To be compatible with Leicas, a lens must have 39mm diameter, 26 tpi, 28.8mm registration and compatible RF coupling. The Soviet manufacturers used an RF coupling that sometimes can be incompatible with Leicas. The other manufacturer that was deviated from the definitive L39 thread was Canon. Their original J series lenses were M39 x 1.1mm pitch, then they made a Universal 39mm mount that would work on either camera by using sloppy threads. (Peter Dechert, Canon Rangefinder Cameras 1933 ~ 68, pg 14.) Canon finally settled on true L39 in 1952. The J series may have been different to avoid any legal action from Leitz. After WWII any manufacturer could use Leitz intellectual property with fear of legal action. The only camera I know of that is true M39 is the Braun Paxette, but with a different registration. One of the Compur shutter sizes is M39. 1 Link to post Share on other sites More sharing options...
01maciel Posted March 27, 2024 Author Share #14 Posted March 27, 2024 I wonder what focal length the Helios 58mm with the extension of the adapters M39->M42->M has at the end. How can this be determined or calculated? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/391630-ltm-%D0%BB%D1%82%D0%BC-%E2%89%A0-leitz-ltm/?do=findComment&comment=5139292'>More sharing options...
pgk Posted March 27, 2024 Share #15 Posted March 27, 2024 1 hour ago, 01maciel said: I wonder what focal length the Helios 58mm with the extension of the adapters M39->M42->M has at the end. How can this be determined or calculated? If you are referring to Flange focal distance, details are here: https://en.wikipedia.org/wiki/Flange_focal_distance 1 Link to post Share on other sites More sharing options...
