x
19 minutes ago, Qfan said:
No I don’t think it’s true. But then ETTR is not my upmost priority, the other issues that have been well documented in this thread are.
No, it is true. Only at base ISO you can fully saturate the sensor and thus maximize the IQ. The benefits of applying ETTR at higher ISO are so small that most people avoid it in order to be safer in preserving the highlights.
24 minutes ago, Qfan said:
This has been discussed earlier in this thread. Please refer to earlier messages.
IIRC,  the solution is to raise the Auto-ISO limit to the maximum.
The only purpose of setting the Auto-ISO limit lower to maximum is to limit the amount of noise. To honor that noise limit, the camera has to start lowering the shutter speed once the ISO limit has been reached.
Reminder:
- noise is not determined by ISO
- noise is determined by exposure: shutter-speed x aperture x scene-light
- there is no such thing as an exposure tringle because exposure completes before ISO is applied.
This guy seems to disagree with you in their article titled "ETTR is critical for high ISO Photography" https://daystarvisions.com/Docs/Tuts/BryanETTR/index.html (Disclaimer: I haven't read it in full and I am also not interested in reading it in full).
My original question is not about ETTR and I also don't care about ETTR, but hopefully the ETTR information you posted and the link above may be useful for others.
Edited by Qfan
No, this is not my solution nor the suggestions of others with the same challenge.
Quote
"Only purpose of setting the Auto-ISO limit lower to maximum is to limit the amount of noise"?  No, I don't believe so.
Quote
Reminder:
While the above is generally true, the statements are too crude, or oversimplified. One also needs to take into account if noise reduction is engaged or not, jpg vs raw, sensor gain design.
In any case, this thread is not for debating about the nature of noise, ISO, or even how to have the lowest noise photos. DPR even has a LOCKED thread due to people circularly arguing about this topic. See here.
As I and others have stated, we simply just want Q to stop reducing shutter speed when a specific minimum shutter speed has been set.
Quote
I am not sure who introduced the "exposure triangle" phrase to this thread because I didn't. Maybe this can be discussed further in a thread about "exposure triangle."
Edited by Qfan
4 hours ago, Qfan said:As I and others have stated, we simply just want Q to stop reducing shutter speed when a specific minimum shutter speed has been set.
Is it so wrong that limits actually mean limits? If the camera underexposes it’s  because we set it that way. This nannying is annoying.
When shooting raw, a sticky shutter speed limit has the same IQ effect as letting the ISO go above the ISO limit (i.e., no ISO limit). If you disagree, please let me know why. Please, do not answer with just "I don't believe so" :).
The reason why most (all?) manufacturers have not implemented a sticky shutter speed limit is that it does not add any functionality. Automatic darkening of an image, once it hits Auto-ISO, is not a useful feature.
First, not all manufacturers have not.
Second, usefulness is in the eyes of the beholder.
Third, calling something "minimum" and giving users the illusion of control, when there is no control, is simply not cool, not to mention laziness.
Sony, Nikon, Fuji, and Leica do it the same way.
Could you please explain the usefulness of a fixed minimum shutter speed limit compared to not setting an ISO limit?
I have explained the usefulness of lowering the shutter speed once the ISO limit has been reached.
Edited by SrMi
Thanks for your continued interest in this feature.
I believe I have explained the reasons and scenarios this feature is needed in previous posts.
That is a misleading article. He maximized the exposure, which is something that you should do regardless of ISO used. Once you have done it, and at higher ISO, you should move the histogram to the left (not ETTR) in order to preserve highlights. ETTR at high ISO would call for maximizing exposure and ISO, which has no benefit over lowering ISO a bit.
I use Manual Mode ... and set the stop and shutter speed myself, and use Auto ISO to correct. Typically I'm wide open, appropriate shutter speed, and Auto ISO. That guarantees the lowest ISO. I'm not concerned with ISO ... I WANT the Moment. The modern Ai Noise Reduction software is amazing. No NR needed here. Full spectrum converted Q, with a Hot Mirror filter, for normal colors. F1.7, 1/250th, 1,600 iso.
I don’t think a flexible shutter speed is the same as increased ISO image quality wise, because increasing the ISO doesn’t allow more light onto the photo sites but a slower shutter speed does. I would argue that between the two, IQ is theoretically better with a slower SS for that reason. But the problem is that shutter speed is a creative exposure tool where ISO is not.
It may seem counterintuitive, but this is why I object to the “limit” not being a limit: SS is a creative choice (even when it’s within a range the photographer has deemed acceptable). ISO is not creative, and yet inexplicably the philosophy of the feature is that ISO remains limited but SS does not!
For this camera, I will raise the auto ISO to a higher limit and deal with whatever noise comes in the occasions it comes. And often, I will shoot in manual-with-auto-ISO, because I need more creative control, not less.
Edited by Pindy
Yes, and that is not what I wrote. I wrote that increasing ISO does not degrade the IQ, and SS, not ISO, determines the IQ.
If you want an SS limit, let the ISO go up (no ISO limit). Why limit the ISO if you do not want to limit the noise (which can be guaranteed only by lowering the SS)?
It's a good solution for Leica and most other cameras. I never set the Auto-ISO limit on my cameras.
Edited by SrMi
OP concluded that the best solution will be to simply underexpose every picture, instead of letting the iso go higher?!
Makes complete sense, since you then just increase exposure in post and add the same noise again. (or worse, depending on software, I suppose?!)
I'm beginning to agree with you.
Great moment shot - love it!!!
  • 2 weeks later...
