2 hours ago, David Wien said:
OK. Thanks Corius. My problem was in understanding the meaning of the term "max shutter speed" which I find ambiguous, and I interpreted it wrongly. I would have expressed this as longest shutter time. The shutter stays open longer when set to 1/50 than 1/1000, which I would equate to slower, and for me the term "max shutter speed is the fastest one!
I just downloaded the German user manua, whichl has this for the relevant paragraph:
Es kann ein maximaler ISO-Wert eingestellt werden, um den Bereich der automatischen Einstellung einzugrenzen ( Maximaler ISO-Wert ). Zusätzlich kann auch eine maximale Belichtungszeit eingestellt werden.
This is crystal clear. I should have consulted the German Bedienungsanleitung earlier; but, since German is my fifth language and by no means as strong as my English, it is a bit of a chore to read!
Thanks again!
David
In the camera it’s called Shutter Speed Limit.
OK. Sorry!  But that is just as bad. A speed limit of 140 km/hr means dont go faster than 140 km/hr! "Maximale Belichtungszeit" (maximum exposure time) is much better.
David
The main message is that there is no "OIS or 1/50 Mystery ".
Btw. all modern cameras have a similar implementation of Auto Iso Setting where you either have a variable shutter speed based on the focal length you have on the camera or an absolute value that would be best suited for your subjects.
David
At least it is not wrong, and logical thinking helps understanding which limit it is.
Camera does not have an “Exposure Time” setting though it may be a better name than shutter speed.
Some cameras use “Min Shutter Speed”.
