Pieter12 Posted January 20, 2024 Share #21 Posted January 20, 2024 Advertisement (gone after registration) The fact that the example of the hair shows less detail indicates to me that the lens is not stopping down. Link to post Share on other sites More sharing options...
Advertisement Posted January 20, 2024 Posted January 20, 2024 Hi Pieter12, Take a look here Leica S 007 what is the latest firmware update and can we use the firmware for the S3? . I'm sure you'll find what you were looking for!
davidmknoble Posted January 22, 2024 Share #22 Posted January 22, 2024 On 1/20/2024 at 4:34 PM, Pieter12 said: The fact that the example of the hair shows less detail indicates to me that the lens is not stopping down. I’m not sure we can tell from these images. The image with the hair looks a little like movement to me (subject movement) or could be that the exposure is longer with the f/stop open than with the f/stop closed, causing loss of detail. However, in either case, the lens would be at fault, so that is the likely needed repair and it doesn’t matter if its f/stop or CS. Link to post Share on other sites More sharing options...
Pieter12 Posted January 22, 2024 Share #23 Posted January 22, 2024 7 hours ago, davidmknoble said: I’m not sure we can tell from these images. The image with the hair looks a little like movement to me (subject movement) or could be that the exposure is longer with the f/stop open than with the f/stop closed, causing loss of detail. However, in either case, the lens would be at fault, so that is the likely needed repair and it doesn’t matter if its f/stop or CS. Not at 1/500 Link to post Share on other sites More sharing options...
davidmknoble Posted January 23, 2024 Share #24 Posted January 23, 2024 7 hours ago, Pieter12 said: Not at 1/500 ??? Not sure I follow… Link to post Share on other sites More sharing options...
LeicaR10 Posted January 23, 2024 Share #25 Posted January 23, 2024 Nick, I sent you a PM so not to derail your thread. r/ Mark Link to post Share on other sites More sharing options...
davidmknoble Posted January 23, 2024 Share #26 Posted January 23, 2024 @Nick Guttridge would love to eventually hear if you find a solution! Link to post Share on other sites More sharing options...
Pieter12 Posted January 23, 2024 Share #27 Posted January 23, 2024 Advertisement (gone after registration) 19 hours ago, davidmknoble said: ??? Not sure I follow… At 1/500, subject motion should not be a factor. Plus the second shot is overexposed, leading to the conclusion the lens is not stopping down to 5.6. Link to post Share on other sites More sharing options...
davidmknoble Posted January 24, 2024 Share #28 Posted January 24, 2024 13 hours ago, Pieter12 said: At 1/500, subject motion should not be a factor. Plus the second shot is overexposed, leading to the conclusion the lens is not stopping down to 5.6. Or the shutter is stuck and not closing fast enough, effectively lowering the shutter speed…. Because it is being used with the central shutter, and because it is over-exposed - either the f/stop is not working or the shutter, both leading to over-exposure and potential appearance in change of focus. For 2 stops (I think that is what the OP said was occurring?) it could be an effectively lower shutter speed. My point was it doesn’t matter, it does appear to be the lens regardless. Link to post Share on other sites More sharing options...
John McMaster Posted January 24, 2024 Share #29 Posted January 24, 2024 Nick is using flash, there is unlikely to be enough ambient light to over expose (other than specular highlights) if the shutter was faulty.... john 1 Link to post Share on other sites More sharing options...
