OK - so I'm curious. Although I no longer own it, is this a Ver 5 or 6 according to the discussion above? Just Curious
8 minutes ago, Lesslemming said:
As a bonus: The Apo Summicron metal cap (14398) fits the Summicron V5, too.
You can improve the fit by adding just a tiny bit of electrical tape to the inside.
Note, however, that the cap sits against the aperture ring and might cause wear to the finish.
To prevent this, I applied a thick coat of matte black revell paint to the bottom of the lens cap which prevents metal rubbing against metal.
Can I ask why you would go to that length to adapt such lens cap when the existing one, the clip-on, works perfectly?
No criticism here, genuinely interested.
Mind you, the first thing I do with a new lens is to get it out of the box, front and rear lens caps go back in, and I fit a high quality protector filter in front and a double sided rear cap. I never use front caps.
To my understanding, a V6 does not exist in our vocabulary here. The V5 is what you seem to have and the next version is the APO. Sometimes , apparently, the normal Summicron you have is also referred to as V6, hence the confusion.
That is a fair question. I find clip-on caps a flimsy and uncharacteristically low budget protection. It’s just a cheap piece of plastic and doesn’t look all that good.
I love the feeling of a well fitted, velvet lined metal cap and feel the premium we pay with Leica entitles me to a free one (but here we are…)
14 minutes ago, kivis said:
yes This latest version of the 50mm f2 non APO, is Version 5. I guess the APO version is considered 6.
I really think the APO is not considered V6 around here, and most places I have been to. It is referred to as “APO”, acknowledging a completely new branch in the lineage. Same goes for the 35mm APO. They exist next to their non-apo kin and are not their replacement (hence both non-apo versions are still in production)
Edited by Lesslemming
  • 7 months later...
On 12/10/2023 at 8:49 PM, evikne said:
I'm still wondering which is the best of the 50mm Summicron (11826) and 50mm Summilux pre-ASPH (11868) at comparable apertures (especially f/2). I haven't seen many direct comparisons.
When I got the Summilux I compared it with my Summicron V at F2, on some portraits, so not a fair comparison. And M-Monochrom, which is rather forgiving. The camara said F2.8 but it really was F2.0
First the Summicron:
Then the Summilux 50 V2 I thought rather new in box:
The background is a tad softer but the difference in the rendering of the hair is evident. It gives the Summilux a slightly more dreamy aspect. Rather nice.
So not equal frames, & just a slight focus difference will show up.
In comparison, the Cron has a lot of evident micro contrast. Look at the glasses.
OOPS - I confused - you asked comparison with the APO-50 Cron - I did that wrong
Edited by Alberti
  • Thanks 2
Thank you very much! No, these are the lenses I wanted to see, you are absolutely right. I downloaded the images to better compare them on my Mac.
