jordisr Posted November 30, 2023 Share #1 Posted November 30, 2023 Advertisement (gone after registration) Hello! I'm trying to develop a TMax 3200 shot at ISO 800 with Adonal and I can't find it in the Massive Dev app. I used the HC-110 for this same setup, but I think the grain is too strong and I want to try the Adonal bottle I have at home. Any suggestions or experience? Many thanks. Link to post Share on other sites More sharing options...
Advertisement Posted November 30, 2023 Posted November 30, 2023 Hi jordisr, Take a look here TMax 3200 at ISO 800 suggestions.. I'm sure you'll find what you were looking for!
Chuck Albertson Posted November 30, 2023 Share #2 Posted November 30, 2023 The Massive Dev Web page (I don't know about an app) has a developing time for Adonal/Rodinal for TMZ @ EI 1000, which is close enough: https://www.digitaltruth.com/devchart.php?Film=&Developer=Rodinal&mdc=Search&TempUnits=C' target='_self Link to post Share on other sites More sharing options...
jordisr Posted November 30, 2023 Author Share #3 Posted November 30, 2023 The difference between ISO 800 and ISO 1000 may not be important, but I would like to be as precise as possible to try to improve the results of the HC-110. I appreciate your reply, thanks Chuck! 1 hour ago, Chuck Albertson said: The Massive Dev Web page (I don't know about an app) has a developing time for Adonal/Rodinal for TMZ @ EI 1000, which is close enough: https://www.digitaltruth.com/devchart.php?Film=&Developer=Rodinal&mdc=Search&TempUnits=C' target='_self Link to post Share on other sites More sharing options...
Danner Posted July 2, 2024 Share #4 Posted July 2, 2024 On 11/30/2023 at 1:44 AM, jordisr said: The difference between ISO 800 and ISO 1000 may not be important, but I would like to be as precise as possible to try to improve the results of the HC-110. I appreciate your reply, thanks Chuck! Precision requires testing. Here's a video on the subject... 2 Link to post Share on other sites More sharing options...
250swb Posted July 3, 2024 Share #5 Posted July 3, 2024 (edited) On 11/30/2023 at 7:44 AM, jordisr said: The difference between ISO 800 and ISO 1000 may not be important, but I would like to be as precise as possible to try to improve the results of the HC-110. I appreciate your reply, thanks Chuck! The Massive Dev Chart is a contribution from hundreds of individuals who all have their own ways of doing things. The best that can be said for the times is they are a starting point allowing you to customise the base time to your ways of dong things. One person may be more vigorous in agitation for example or use a different light meter to measure the exposure and there are no precise ways to quantify this. And that is true of any developer and film combination time you can find on the internet. So if 7 minutes at 20c (or whatever) gives a nice rich negative first time you try the next time you try you can think about 'was there enough shadow detail?' or 'were the highlights too dense?' and add or subtract twenty seconds. The Zone System for example is the most complicated and precise development regimes you can use but each person has to do their own tests for it to work, and on a much simpler level it's the same for dunking TMax 3200 into Rodinal. Edited July 3, 2024 by 250swb 2 Link to post Share on other sites More sharing options...
