Trutta Posted October 21, 2023 Share #1 Posted October 21, 2023 Advertisement (gone after registration) Please excuse me, if this has been beaten to death, I was curious to see if the LTM summaron couples with the rangefinder on the M2? Link to post Share on other sites More sharing options...
Advertisement Posted October 21, 2023 Posted October 21, 2023 Hi Trutta, Take a look here 3.5cm summaron on an M2 . I'm sure you'll find what you were looking for!
Topsy Posted October 21, 2023 Share #2 Posted October 21, 2023 I have a 3.5 Summaron LTM and an adapter for screw to M mount and it works fine on my M2. I did first try a cheap aftermarket adapter but it din't work too well it was very tight but I found a geniuine adapter and the set up is fine on any of my M caleras. Link to post Share on other sites More sharing options...
dpitt Posted October 21, 2023 Share #3 Posted October 21, 2023 AFAIK, any LTM range finder coupled lens will be range finder coupled when using the right adapter. Choose the right adapter to bring up the frame lines for your lens. If the LTM lens has an infinity lock, you may need a special adapter with a cutout to reach infinity. Leica has made these in the past, and some can be found in China today, but I have heard lots of issues where the Chinese adapters is not exactly the right thickness to focus correctly. Link to post Share on other sites More sharing options...
Anbaric Posted October 21, 2023 Share #4 Posted October 21, 2023 (edited) If you get an original Leitz adapter, you want an ISOOZ engraved like this one: https://wiki.l-camera-forum.com/leica-wiki.en/index.php/ISOOZ There is an earlier variant of the ISOOZ from the M3-only era that will also bring up the correct framelines, but has a shorter cutout that may not work with all infinity locks (it will just be engraved '135 cm' and doesn't mention the M2). If you're also shooting Leica M digital, you may want a modern 'type III' adapter like the latest version of the Rayqual 35/135, which works with both infinity locks and 6-bit coding. Edited October 21, 2023 by Anbaric Link to post Share on other sites More sharing options...
Trutta Posted October 22, 2023 Author Share #5 Posted October 22, 2023 Thank you ! Link to post Share on other sites More sharing options...
