xveruskax Posted August 31, 2023 Share #1 Posted August 31, 2023 Advertisement (gone after registration) Purchased a used M10-P in near mint condition that’s worked perfectly for a while now. Occasionally the shutter gets stuck but it works fine thereafter. I’ve heard that can be an issue. Today however had a total crazy and terrifying thing happen. I have been shooting with a Canon 50mm f1.4 LTM lens using an adapter, although I doubt that factors into this. Upon turning on camera, the screen started to flicker colors and then would not respond. I had to take battery out, switch the battery with another, take the SD card in and out. Didn’t seem to help. I finally switched the lens to my 35mm Summilux and it started up and I could shoot again. I’ve read that the symptoms presented ultimate can result in the need for service and a control board replacement even but the fact that it worked fine with a Leica lens was interesting or perhaps just pure coincidence. Besides recommending service checkup, any other thoughts? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/381494-total-brain-freeze-m10-p/?do=findComment&comment=4847509'>More sharing options...
Advertisement Posted August 31, 2023 Posted August 31, 2023 Hi xveruskax, Take a look here Total brain freeze M10-P. I'm sure you'll find what you were looking for!
prk60091 Posted August 31, 2023 Share #2 Posted August 31, 2023 (edited) try a NEW SD Card? sometimes when they get fail stuff like this happens... otherwise ????? Edited August 31, 2023 by prk60091 Link to post Share on other sites More sharing options...
frame-it Posted August 31, 2023 Share #3 Posted August 31, 2023 (edited) and which LTM Adapter are you using? the canon lens is obviously uncoded..that could also cause the camera to go into a lens detect "loop" and crash. Edited August 31, 2023 by frame-it Link to post Share on other sites More sharing options...
xveruskax Posted August 31, 2023 Author Share #4 Posted August 31, 2023 18 minutes ago, frame-it said: and which LTM Adapter are you using? the canon lens is obviously uncoded..that could also cause the camera to go into a lens detect "loop" and crash. Was using a Light Lab Lens 50-75mm adapter. The camera was at first response with the 35mm Lux but now it’s doing it again. Freezes up and the camera isn’t even reading the lens because changing f-stop in lens doesn’t register in the internal metering. The screen freezes immediately after turning camera on. Never heard of lens loop crash. What would I do to uncrash it to see if it was just that alone. Link to post Share on other sites More sharing options...
xveruskax Posted August 31, 2023 Author Share #5 Posted August 31, 2023 2 hours ago, Al Brown said: Your LTM adapter does not have a full outer circle, is it cut below over one third of the ring bottom part so the 6-bit sensor is somewhat exposed. Many LTM adapters have a flange cutout that leaves the 6-bit code reader uncovered. That could confuse the camera properly. Usually just a "no lens connected" message is displayed, but it *could* cause the camera to lose it. Try: - Different card - Shooting without this adapter, with your Summilux, and do a big round of image taking. Could be the card, if shooting with Summilux and a new card is OK could be the LTM adapter (buy one that hass FULL outer edges so the 6-bit light sensor on the mount is not confused), if the camera fails on both of these it is the board. I talked to Leica SF which is local store and they advised trying a newer "faster" card so I'll do that. I only bought the camera from an online camera store like two months ago so it's still under their 6 month warranty for all used items. It was in Like Mint condition and seemed perfect until now. If the new (formatted on computer) card does not register an improvement, I can send it back to the place I bought it under warranty. MPB, where I bought it from, said they would try an in-house repair (when possible) or ship it off for Leica repair if need be. However, depending on issue they could either offer a comparable replacement (again under warranty) or a refund. I know anything with electronics can fail and it may ultimately end up being the control board. Link to post Share on other sites More sharing options...
dugby Posted August 31, 2023 Share #6 Posted August 31, 2023 (edited) What firmware version is in the M10-P ? As the M10-P is a 2020 era camera, try to chose a new SD card from the 2018 to 2020 years, and not the latest 2023 period. Hardware compatibility is extremely important with any IT technology. Edited August 31, 2023 by dugby 1 Link to post Share on other sites More sharing options...
xveruskax Posted August 31, 2023 Author Share #7 Posted August 31, 2023 Advertisement (gone after registration) 41 minutes ago, dugby said: What firmware version is in the M10-P ? As the M10-P is a 2020 era camera, try to chose a new SD card from the 2018 to 2020 years, and not the latest 2023 period. Hardware compatibility is extremely important with any IT technology. I managed to get back into the menu once during the several attempts to troubleshoot and I didn't think to check firmware but I did update it back in June when I bought it to the current one at that time. Leica Store recommended faster card so I'll be trying that for now. I was shooting a 200 speed 128gb card so I'll be trying a 280 speed. I doubt it will make any difference given the glitching. Link to post Share on other sites More sharing options...
frame-it Posted August 31, 2023 Share #8 Posted August 31, 2023 (edited) 4 minutes ago, xveruskax said: I managed to get back into the menu once during the several attempts to troubleshoot and I didn't think to check firmware but I did update it back in June when I bought it to the current one at that time. Leica Store recommended faster card so I'll be trying that for now. I was shooting a 200 speed 128gb card so I'll be trying a 280 speed. I doubt it will make any difference given the glitching. as @Al Brown said, first remove that adapter then use only the 35mm M lens for a few hours or half a day and see if all is fine if its still messed up, then decide if you wanna return it or send it to Leica Edited August 31, 2023 by frame-it 1 Link to post Share on other sites More sharing options...
xveruskax Posted September 1, 2023 Author Share #9 Posted September 1, 2023 (edited) 4 hours ago, frame-it said: as @Al Brown said, first remove that adapter then use only the 35mm M lens for a few hours or half a day and see if all is fine if its still messed up, then decide if you wanna return it or send it to Leica Returned it by end of day to see if they can repair it I get a refund. Using 35mm Lux or 50mm Lux did nothing. Screen would usually not load or just show mostly purple rows while glitching. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited September 1, 2023 by xveruskax Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/381494-total-brain-freeze-m10-p/?do=findComment&comment=4847801'>More sharing options...
newtoleica Posted September 1, 2023 Share #10 Posted September 1, 2023 Needs serious work on the electronics that..... Link to post Share on other sites More sharing options...
LocalHero1953 Posted September 1, 2023 Share #11 Posted September 1, 2023 Return for a refund. Like Mint? No. Link to post Share on other sites More sharing options...
charlesphoto99 Posted September 1, 2023 Share #12 Posted September 1, 2023 Get the refund. Third party repairers can't do electronics, sensors, etc on M digital bodies. And if it goes off to Leica, it will take months (I know, my M10-R is there for unresponsive back buttons when it gets over 75 degrees F outside). Link to post Share on other sites More sharing options...
Jeff S Posted September 1, 2023 Share #13 Posted September 1, 2023 After getting the refund (hopefully without problem), buy from a reputable Leica dealer. There are many in the US that I would rely on before shopping MPB or similar. Jeff Link to post Share on other sites More sharing options...
xveruskax Posted September 1, 2023 Author Share #14 Posted September 1, 2023 8 hours ago, LocalHero1953 said: Return for a refund. Like Mint? No. Electronics die. On anything. Even a brand new camera out of the box. Link to post Share on other sites More sharing options...
xveruskax Posted September 1, 2023 Author Share #15 Posted September 1, 2023 3 hours ago, charlesphoto99 said: Get the refund. Third party repairers can't do electronics, sensors, etc on M digital bodies. And if it goes off to Leica, it will take months (I know, my M10-R is there for unresponsive back buttons when it gets over 75 degrees F outside). Their policy is to attempt "repair" but if it does need to get shipped off to Leica, knowing that will take months, they will factor that in and ask if that's worth waiting on my part. I cannot get a refund until they assess the camera's issue and I just shipped it off yesterday. Optimistically they determine that it requires complete overhaul in the next couple of weeks and issue a refund. They don't have Leica M10-Ps in stock now so they can't offer a comparable replacement. Link to post Share on other sites More sharing options...
LocalHero1953 Posted September 1, 2023 Share #16 Posted September 1, 2023 58 minutes ago, xveruskax said: Electronics die. On anything. Even a brand new camera out of the box. Isn’t that warranties are for? Link to post Share on other sites More sharing options...
Jeff S Posted September 1, 2023 Share #17 Posted September 1, 2023 4 hours ago, xveruskax said: Their policy is to attempt "repair" but if it does need to get shipped off to Leica, knowing that will take months, they will factor that in and ask if that's worth waiting on my part. I cannot get a refund until they assess the camera's issue and I just shipped it off yesterday. Optimistically they determine that it requires complete overhaul in the next couple of weeks and issue a refund. They don't have Leica M10-Ps in stock now so they can't offer a comparable replacement. Exactly why I buy elsewhere. Jeff 1 Link to post Share on other sites More sharing options...
xveruskax Posted September 3, 2023 Author Share #18 Posted September 3, 2023 On 9/1/2023 at 2:25 PM, Jeff S said: Exactly why I buy elsewhere. Jeff I regret responding to you. Link to post Share on other sites More sharing options...
Jeff S Posted September 3, 2023 Share #19 Posted September 3, 2023 3 hours ago, xveruskax said: I regret responding to you. You didn’t, before this nice comment. Jeff Link to post Share on other sites More sharing options...
xveruskax Posted September 14, 2023 Author Share #20 Posted September 14, 2023 UPDATE: ended up getting refund from mpb since the M10-P froze completely and was unresponsive. Purchased another used M10-P from Leica store that happened to have a black version in stock. Super hard to find. 1 Link to post Share on other sites More sharing options...
