mholeica Posted August 30, 2023 Share #1 Posted August 30, 2023 (edited) Advertisement (gone after registration) Had an evening out with the family today and my Wife took a photo of my son and I with our Q3. The photo was shot uncropped, I was surprised to see that with lens correction applied my forehead looks elongated but with the lens correction NOT applied the proportion was more natural/real. I have attached two photos, bottom one with lens correction applied in ON1 (the OOC JPEG looks similar in terms of proportions) and the second, top one, with no lens correction applied. The photo is no lens correction applied is the one with the less elongated forehead - which is more my head shape! I understand that photos can be distorted if you shoot wide and stand close to the camera but I thought lens correction would fix this rather than emphasize it like in this case. Can anyone explain? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited August 30, 2023 by mholeica named top and bottom photo Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/381459-lens-correction-wrong/?do=findComment&comment=4847003'>More sharing options...
Advertisement Posted August 30, 2023 Posted August 30, 2023 Hi mholeica, Take a look here Lens correction wrong? . I'm sure you'll find what you were looking for!
jdlaing Posted August 30, 2023 Share #2 Posted August 30, 2023 Very simple. Do not apply lens correction in post processing. 1 Link to post Share on other sites More sharing options...
mholeica Posted August 31, 2023 Author Share #3 Posted August 31, 2023 (edited) 14 minutes ago, jdlaing said: Very simple. Do not apply lens correction in post processing. I shoot RAW + JPEG and usually keep JPEGs unless I am printing something out or needing to brighten. It seems like the camera applies lens correction to the JPEGs, I am now wondering if it is better to not do this and how to turn it off in camera if it is even possible. Edited August 31, 2023 by mholeica Link to post Share on other sites More sharing options...
jdlaing Posted August 31, 2023 Share #4 Posted August 31, 2023 Just now, mholeica said: I shoot RAW + JPEG. It seems like the camera applies lens correction to the JPEGs, I am now wondering if it is better to not do this and how to turn it off in camera if it is even possible. I don’t believe you can turn it off. Post a picture of the raw converted to jpeg without any post processing corrections done. Link to post Share on other sites More sharing options...
mholeica Posted August 31, 2023 Author Share #5 Posted August 31, 2023 8 minutes ago, jdlaing said: I don’t believe you can turn it off. Post a picture of the raw converted to jpeg without any post processing corrections done. Here is the photo which is RAW to JPEG with no post processing or lens correction applied. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/381459-lens-correction-wrong/?do=findComment&comment=4847040'>More sharing options...
jdlaing Posted August 31, 2023 Share #6 Posted August 31, 2023 Perfect. Link to post Share on other sites More sharing options...
mholeica Posted August 31, 2023 Author Share #7 Posted August 31, 2023 Advertisement (gone after registration) Why does lens correction make it worse? Is it something only significantly noticeable for people? As I assume lens correction should make it better. Link to post Share on other sites More sharing options...
frame-it Posted August 31, 2023 Share #8 Posted August 31, 2023 are you using C1 or LR ? Link to post Share on other sites More sharing options...
WeiterWinkel Posted August 31, 2023 Share #9 Posted August 31, 2023 The effect of shooting with an upward angle adds to the effect. Link to post Share on other sites More sharing options...
SAronian Posted August 31, 2023 Share #10 Posted August 31, 2023 In my experience the in-camera correction (JPEG) is different than what is produced by Lightroom Classic (DNG) Even though RAW software is supposed to be using the descriptive tag embedded within the DNG file. One can only assume the out of camera version is correct and the DNG is incorrect Link to post Share on other sites More sharing options...
Miltz Posted August 31, 2023 Share #11 Posted August 31, 2023 The reason is you’re applying double lens correction in your software ON1. You see the RAW images have all the corrections built in, your software is doing it again which is ruining your shots. If you open the raw file in Adobe Camera RAW or Lightroom you don’t have this issue. Just don’t apply additional corrections in your ON1 software. Link to post Share on other sites More sharing options...
mholeica Posted September 2, 2023 Author Share #12 Posted September 2, 2023 On 8/31/2023 at 1:53 AM, frame-it said: are you using C1 or LR ? I am using ON1. But the issue is with the in camera JPEG lens correction too. On 8/31/2023 at 8:32 AM, Miltz said: The reason is you’re applying double lens correction in your software ON1. You see the RAW images have all the corrections built in, your software is doing it again which is ruining your shots. If you open the raw file in Adobe Camera RAW or Lightroom you don’t have this issue. Just don’t apply additional corrections in your ON1 software. When processing a RAW it’s fairly easy to ‘fix‘ this issue, as like people have said above, just don’t apply lens correction. The issue however is that I tend to prefer to just keep the JPEGs and only process those that are either too dark/ bright or if I want to print out the photo. The JPEG OOC usually looks pretty good already but it applies the lens correction which gives the effect described above. This also makes me think that the RAW does not have lens correction applied but has the data for lens correction and if I choose to apply it in ON1 it makes it look like the OOC JPEG. It’s a strange one as lens correction is supposed to make it less distorted. Link to post Share on other sites More sharing options...
frame-it Posted September 2, 2023 Share #13 Posted September 2, 2023 16 minutes ago, mholeica said: I am using ON1. But the issue is with the in camera JPEG lens correction too. When processing a RAW it’s fairly easy to ‘fix‘ this issue, as like people have said above, just don’t apply lens correction. The issue however is that I tend to prefer to just keep the JPEGs and only process those that are either too dark/ bright or if I want to print out the photo. The JPEG OOC usually looks pretty good already but it applies the lens correction which gives the effect described above. This also makes me think that the RAW does not have lens correction applied but has the data for lens correction and if I choose to apply it in ON1 it makes it look like the OOC JPEG. It’s a strange one as lens correction is supposed to make it less distorted. well, just for fun, download a trial version of C1 and open a Leica Q DNG and reset the cropping Link to post Share on other sites More sharing options...
mholeica Posted September 5, 2023 Author Share #14 Posted September 5, 2023 On 9/2/2023 at 10:51 AM, frame-it said: well, just for fun, download a trial version of C1 and open a Leica Q DNG and reset the cropping Just got round to downloading the C1 trial but remembered I had a trial already so won't work unfortunately, not even with another email address. Link to post Share on other sites More sharing options...
jaapv Posted September 5, 2023 Share #15 Posted September 5, 2023 The problem is that a wideangle lens will have two types of distortion. The most obvious one is linear distortion-barrel, pincushion or moustache- and the other one is perspective distortion -egg-shaped heads- which affects three-dimensional objects close to the corners and edges and is a geometrical function, not a lens error. Correcting one can/will worsen the other. Link to post Share on other sites More sharing options...
mholeica Posted September 5, 2023 Author Share #16 Posted September 5, 2023 2 hours ago, jaapv said: The problem is that a wideangle lens will have two types of distortion. The most obvious one is linear distortion-barrel, pincushion or moustache- and the other one is perspective distortion -egg-shaped heads- which affects three-dimensional objects close to the corners and edges and is a geometrical function, not a lens error. Correcting one can/will worsen the other. Yes it’s really interesting turning lens correction on and then off in software, head shape might improve but you get distortion at the fringe. Shooting 35mm crop for near by people is definitely the best. Link to post Share on other sites More sharing options...
jaapv Posted September 5, 2023 Share #17 Posted September 5, 2023 If you want to correct the perspective distortion at the edges (eg eggheads in the corner) you do so by introducing barrel distortion in the two-dimensional rendering. Link to post Share on other sites More sharing options...
