McGirton Posted August 2, 2023 Share #1 Posted August 2, 2023 Advertisement (gone after registration) Hi everyone, did anybody here take apart their M10? I have a slightly sticky / bit smooth shutter button and an on/off switch that could probably go easier. I am aware how to take an M9 / M240 top plate off, but I have found no info on the M10. Is it the same few screws? Also, maybe I can solve the button issue without taking the camera apart? I’ve read about spraying some electronics contact spray into the button? I would rather not send it in for 6 months.. Link to post Share on other sites More sharing options...
Advertisement Posted August 2, 2023 Posted August 2, 2023 Hi McGirton, Take a look here Disassembling M10 / Sticky shutter release. I'm sure you'll find what you were looking for!
Gelatino Posted August 2, 2023 Share #2 Posted August 2, 2023 I don't want to lead you in a wrong direction, but my M11 shutter button had an issue that was solved by unscrewing it, I mean the large diameter piece next to the top plate (you may need an ad hoc key) and add a thin washer (?). The Leica technician said the same problem occured on the M10-P, and it was the way to solve it; so I suppose both shuttter buttons on M10 and M11 are identical. Hope it helps. 1 Link to post Share on other sites More sharing options...
charlesphoto99 Posted August 2, 2023 Share #3 Posted August 2, 2023 Same two screws - one in the battery mouth and a longer one on the other side. 1 Link to post Share on other sites More sharing options...
McGirton Posted August 2, 2023 Author Share #4 Posted August 2, 2023 5 hours ago, Gelatino said: I don't want to lead you in a wrong direction, but my M11 shutter button had an issue that was solved by unscrewing it, I mean the large diameter piece next to the top plate (you may need an ad hoc key) and add a thin washer (?). The Leica technician said the same problem occured on the M10-P, and it was the way to solve it; so I suppose both shuttter buttons on M10 and M11 are identical. Hope it helps. That’s interesting. I know the tool used to unscrew the top of the shutter button, maybe I’ll get one and try this before I take the top plate off. Link to post Share on other sites More sharing options...
Gelatino Posted August 2, 2023 Share #5 Posted August 2, 2023 The tool looks like a keyhole. I know that Leica provides one for the Leica stores, but it may be convenient and not so difficult to make one from a 3mm aluminium plate. Link to post Share on other sites More sharing options...
Adam Bonn Posted August 5, 2023 Share #6 Posted August 5, 2023 On 8/2/2023 at 10:14 AM, McGirton said: I am aware how to take an M240 top plate off Same principle, but on the m10 the screw in the battery compartment side isn’t hiding under the baseplate catch Link to post Share on other sites More sharing options...
KFo Posted August 6, 2023 Share #7 Posted August 6, 2023 Advertisement (gone after registration) Here is my take on this: Removing shutter button. 1 2 Link to post Share on other sites More sharing options...
