SAH Posted July 14, 2023 Share #1 Posted July 14, 2023 Advertisement (gone after registration) Q3 seems to change autofocus mode on its own. It does this when switching between remote function w FOTOS back to EVF use, but also I’ll pick it up and it seems to have just changed from last use. Anyone else? Link to post Share on other sites More sharing options...
Advertisement Posted July 14, 2023 Posted July 14, 2023 Hi SAH, Take a look here Q3 autofocus mode changes on its own . I'm sure you'll find what you were looking for!
Ianrandy Posted July 14, 2023 Share #2 Posted July 14, 2023 You've not got it set to Intelligent AF have you? That'll switch between AF-s and AF-c based on what the camera thinks is best Link to post Share on other sites More sharing options...
SAH Posted July 14, 2023 Author Share #3 Posted July 14, 2023 No - I checked iAF. Not on. This is weird..... Link to post Share on other sites More sharing options...
pixelpunch Posted July 15, 2023 Share #4 Posted July 15, 2023 (edited) I have noticed the same behaviour. The camera set itself in AFs mode from when I use the iPhone screen for selecting a focus point. Then it doesn't reset when I disconnect. Edited July 15, 2023 by pixelpunch Link to post Share on other sites More sharing options...
jaapv Posted July 15, 2023 Share #5 Posted July 15, 2023 Does it make a difference whether you disconnect. on your phone or. on the camera? Link to post Share on other sites More sharing options...
BobsFirstLeica Posted July 15, 2023 Share #6 Posted July 15, 2023 12 hours ago, pixelpunch said: I have noticed the same behaviour. The camera set itself in AFs mode from when I use the iPhone screen for selecting a focus point. Then it doesn't reset when I disconnect. Maybe I am missing something but this, to me, logically, would be consistent with what I would expect is normal behavior. If I use FOTOS I am using the camera mounted on a tripod or sitting someplace stable. The subject, or even a self portrait, is relatively stable so AFs seems like the logical AF choice. No need for AFc....maybe iAF for a little movement but doubtful the programmers saw it necessary. The camera therefore sets itself to AFs, the photo is taken (or not taken), and when one disconnects the phone from the camera, the camera defaults to the last AF mode used.....which is AFs. What may not make sense, and may be an issue, is the OP's comment: "but also I’ll pick it up and it seems to have just changed from last use." However, so far, this has not happened with my Q3. Bob Link to post Share on other sites More sharing options...
SAH Posted July 15, 2023 Author Share #7 Posted July 15, 2023 Advertisement (gone after registration) Now that you mention it, it makes sense that REMOTE mode would change the AF mode and then it would stay set that way since it was the last setting. The issue of the camera changing its settings from use to use seems to have settled out. Did a hard reset by mistake and - poof - no more problems.. Doesn't explain why this occurred own first place though..... Link to post Share on other sites More sharing options...
pixelpunch Posted July 16, 2023 Share #8 Posted July 16, 2023 On 7/15/2023 at 6:45 PM, BobsFirstLeica said: Maybe I am missing something but this, to me, logically, would be consistent with what I would expect is normal behavior. Yes. My gripe with the behaviour is that it doesn't go back to the mode it was before connecting to the Fotos app once I'm done. And it's also not only AFs, but also the AF mode that gets set to ”Field”. But sure, now that I know about it, it's not a big problem. Made me miss a few shots though, and also made me wonder who had used my camera without telling me. : ) Link to post Share on other sites More sharing options...
pixelpunch Posted July 16, 2023 Share #9 Posted July 16, 2023 On 7/15/2023 at 10:06 AM, jaapv said: Does it make a difference whether you disconnect. on your phone or. on the camera? Good question. I'll check it out next time. Link to post Share on other sites More sharing options...
