hcklr Posted June 18, 2023 Share #1 Posted June 18, 2023 Advertisement (gone after registration) I have the cable that came with the Q3 to transfer images to my phone (lightning on one end) but is there really NO way to transfer images to my Mac or iPad with USB-C? I dreamt of never having to take the handgrip off my camera, but I still have to take it off every single time I need to get the SD card out. I really thought the supplied USB-C to lightning meant that I could also use regular USB-C to transfer to my Mac or iPad....Any help/info?? Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted June 18, 2023 Posted June 18, 2023 Hi hcklr, Take a look here My new Leica Q3 and USB-C - Quick Question. I'm sure you'll find what you were looking for!
Stephen_C Posted June 18, 2023 Share #2 Posted June 18, 2023 See page 83 of the downloadable instruction manual: Quote DATA TRANSFER Data can be conveniently transferred to mobile devices via Leica FOTOS. Alternatively, a card reader or USB cable can be used for the transfer. As the manual clarifies that is not limited to transfer of images merely to "mobile devices”. You select in the camera the appropriate setting and: Quote PTP allows a data transfer to computers using MacOS or Windows with PTP-capable programs, as well as tethering to Capture One Pro and Lightroom Classic Stephen 1 Link to post Share on other sites More sharing options...
rustyrus Posted June 18, 2023 Share #3 Posted June 18, 2023 https://leica-camera.com/sites/default/files/pm-95826-Leica-Q3_EN_1.1.pdf Of course you can use a USB cable, Fotos App, Iphone cable etc. Link to manual above 1 Link to post Share on other sites More sharing options...
WeiterWinkel Posted June 18, 2023 Share #4 Posted June 18, 2023 USB-C is kind of black magic. Not every cable with a USB-C plug on each side is capable of data transfer, some are just for charging. And this is just the beginning of the mind boggling plentitude of USB-C/Thunderbolt-cables. 3 Link to post Share on other sites More sharing options...
Qwertynm Posted June 18, 2023 Share #5 Posted June 18, 2023 Ideally use a 100W usb-c cable. If you have a new-ish macbook without magsafe use the charging cable of your laptop. Otherwise consider buying one as the download speed of usb-c charging cables will be slow 1 Link to post Share on other sites More sharing options...
hcklr Posted June 18, 2023 Author Share #6 Posted June 18, 2023 Many thanks! I figured out where in the camera to change the setting to mass storage mode. Works perfectly! Thanks all! 1 1 Link to post Share on other sites More sharing options...
GaryWayne Posted June 20, 2023 Share #7 Posted June 20, 2023 Advertisement (gone after registration) On 6/18/2023 at 10:23 AM, hcklr said: Many thanks! I figured out where in the camera to change the setting to mass storage mode. I came here specifically to ask how to do this and you've got the answer: Mass Storage Mode. The manual says to use PTP but that sure didn't work. I've done a number of google searches and even sent an email to Leica customer support. They're all busy building Q3's and can't be bothered with questions. I hadn't tried mass storage mode and that was the answer Thank you so much! No more removal of either the battery or SD card...life is good. 1 Link to post Share on other sites More sharing options...
LeitzcameraAG Posted September 25, 2023 Share #8 Posted September 25, 2023 May I ask exactly where in the settings is this? Do I need to set Leica Q3 to 'mass storage mode' or my receiving device like iPad Pro? Link to post Share on other sites More sharing options...
Aram Langhans Posted September 26, 2023 Share #9 Posted September 26, 2023 5 hours ago, LeitzcameraAG said: May I ask exactly where in the settings is this? Do I need to set Leica Q3 to 'mass storage mode' or my receiving device like iPad Pro? Page 5 of the menus, Choose Camera Settings, then scroll down to USB-Mode and choose Mass storage. 2 1 Link to post Share on other sites More sharing options...
Denebola Posted September 26, 2023 Share #10 Posted September 26, 2023 Sometimes I download using USB-C cable (PTP with windows, Apple MFi for iPad), other via wireless, so I set it as "Select on connection", and I choose the right one time after time depending by the device and connection type. Den PS: using USB-C cable and Apple MFi sometimes not all the images are shown in Leica Fotos. I've already opened a ticket with Leica Support. Maybe other experienced this same behavior? Link to post Share on other sites More sharing options...
Qwertynm Posted September 26, 2023 Share #11 Posted September 26, 2023 vor 57 Minuten schrieb Denebola: PS: using USB-C cable and Apple MFi sometimes not all the images are shown in Leica Fotos. I've already opened a ticket with Leica Support. Maybe other experienced this same behavior? try mass storage. what happens then? I use LR to import images directly from the camera and mass storage seems way faster than Apple MFi too... 1 Link to post Share on other sites More sharing options...
jps1 Posted September 27, 2023 Share #12 Posted September 27, 2023 PTP mode is useful for controlling the device with Capture One or other. Link to post Share on other sites More sharing options...
Denebola Posted September 27, 2023 Share #13 Posted September 27, 2023 On 9/26/2023 at 10:34 AM, Qwertynm said: try mass storage. what happens then? I use LR to import images directly from the camera and mass storage seems way faster than Apple MFi too... With mass storage (with Windows, of course), you use a standard Explorer interface. With PTP, you can use some native application (i.e. Foto) to download, slightly more immediate to manage (and using this it is less easy for inexperienced users to make mistakes). Download performance depend by several factors, so the experience tells to everybody what is their best method to follow. Download performance depend by several factors, so the experience tell to anybody what is the best method to follow. BTW Leica support answered my ticket specifying that the USB-C cable connection is still in beta and will be improved in the next. Den Link to post Share on other sites More sharing options...
LeitzcameraAG Posted September 28, 2023 Share #14 Posted September 28, 2023 On 9/25/2023 at 8:38 PM, Aram Langhans said: Page 5 of the menus, Choose Camera Settings, then scroll down to USB-Mode and choose Mass storage. Thank you!! I was able to change it and can now see the camera in Files on iPad Pro. goodbye, SD card dongle 😂 Link to post Share on other sites More sharing options...
red_got Posted November 28, 2023 Share #15 Posted November 28, 2023 Does anyone actually have success with Tethered Capture with Lightroom and Q3 when connecting using USB and PTP? I couldn’t seem to get it to work at all. Link to post Share on other sites More sharing options...
UliKK Posted November 29, 2023 Share #16 Posted November 29, 2023 Yes, in my case it works. Also live-view. I "live"-connect the camera to the computer first (both are up and running) and then the setting needs to be changed to PTP. I have one USB-C to USB-C cable which does not connect the two. All others work. Using latest MacOS and Capture1 v23. Link to post Share on other sites More sharing options...
JLS Posted August 27, 2024 Share #17 Posted August 27, 2024 - I have many of the identical questions - The only ‘Cable’ which came with the Q3 was a Multi-Ported adapter to an iOS “Lightning” Plug. The “Lightning” Plug does not work with the iPad, only the iPhone. Hence, if you download the Leica FOTOS App, you cannot connect “Cable To Cable” with an iPad. [The iPhone is a “Phone”, and too small to utilize for “The End All, Be All” with many items, including a camera the quality of the Q3. - I also attempted to use a USB-C to USB-C Cable, plugging one into the Q3 & the other into the iPad. THAT DOES NOT WORK! - The only way I could use the iPad was through the FOTOS App, and connecting utilizing Bluetooth. [Candidly, that’s NOT really what I wanted……My desire was a “Wired” connection.] - Frustrating! Moreover, if you use the Leica FOTOS App, you are ostensibly giving access to Leica. If anything has been proven, it’s that nothing is secure. Hence, I don’t wish anyone or any company to have access to any data. (I attempted to connect & deny all access to Leica, & the App connection was ‘Disconnected’. So, I had to start over, and give Leica “Partial Access”. Why? - It is “MY” Camera - The photographs I take are “MINE” - Yet, if you don’t allow access to Leica for use of the APP, you cannot utilize ‘Their’ App, nor the features of controlling or re-setting Q3 Settings. Yet, the Customer has paid a premium for the Q3 & the potential transfer capabilities which Leica advertises. Wow! - If I have missed, or incorrectly stated, my findings I’d appreciate being corrected. Otherwise, it appears that Leica [Like So Many Other Companies, and Governments] have access to My Property, even thought I have paid for this property [i.e. the Q3]. I find this connection matter unacceptable. Link to post Share on other sites More sharing options...
SrMi Posted August 27, 2024 Share #18 Posted August 27, 2024 18 minutes ago, JLS said: - Frustrating! Moreover, if you use the Leica FOTOS App, you are ostensibly giving access to Leica. If anything has been proven, it’s that nothing is secure. Hence, I don’t wish anyone or any company to have access to any data. (I attempted to connect & deny all access to Leica, & the App connection was ‘Disconnected’. So, I had to start over, and give Leica “Partial Access”. Why? - It is “MY” Camera - The photographs I take are “MINE” - Yet, if you don’t allow access to Leica for use of the APP, you cannot utilize ‘Their’ App, nor the features of controlling or re-setting Q3 Settings. Yet, the Customer has paid a premium for the Q3 & the potential transfer capabilities which Leica advertises. Wow! I think you are too paranoid. Unless you get an infected version of the FOTOS app, there is no chance the app will siphon your images to the Leica overlord. The app needs access to local storage to save pictures; otherwise, it does not work. I assume you want to transfer images to your iPad. Aren't you worried that Apple will steal your images? 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 27, 2024 Share #19 Posted August 27, 2024 Ignoring the second half of your post, have you tried the solutions explained earlier in the thread (e.g. #14), including selecting Mass Storage mode? Link to post Share on other sites More sharing options...
Qwertynm Posted August 29, 2024 Share #20 Posted August 29, 2024 On 8/27/2024 at 7:40 PM, JLS said: Yet, if you don’t allow access to Leica for use of the APP, you cannot utilize ‘Their’ App, nor the features of controlling or re-setting Q3 Settings. Yet, the Customer has paid a premium for the Q3 & the potential transfer capabilities which Leica advertises. Wow! I think you are misunderstanding the security settings of your iPhone. hope you didn’t pay your Q3 with a credit or debit card. Otherwise they now have your banc info as well 😵 I agree that it’s a bit of an annoyance that Leica delivers the Q3 with a lightning cable. You need a USB-C data cable, not just a charging cable. And then set your cameras usb-connection to ‚mass storage‘. if you want to leave your camera grip on you either send the photos trough the Leica app or need a usb-c data cable. Both viable solutions and in my experience both seem to be comparable in terms of transfer speed due to the limiting read speed of uhs-ii cards. There is no conspiracy there and your rant is a bit unfounded. Link to post Share on other sites More sharing options...
