jstanton8869 Posted June 23, 2023 Share #21 Posted June 23, 2023 Advertisement (gone after registration) Got an answer on this from Leica in the UK. DOF preview works fine in AFs but not in AFC or the new iAF mode. I've tried this with my Q3 and Q2M and can confirm this is correct. "If you press Shutter Release the aperture closes and the DoF increases. But only with AFs! With AFc and iAF there is no DoF preview, because the camera always uses open aperture for refocusing. Should be the same for Q2 and Q3 (except that Q2 has no iAF)" 1 1 Link to post Share on other sites More sharing options...
Advertisement Posted June 23, 2023 Posted June 23, 2023 Hi jstanton8869, Take a look here No depth of field preview on Q3 with AF. I'm sure you'll find what you were looking for!
MediaFotografie Posted June 23, 2023 Share #22 Posted June 23, 2023 vor 15 Minuten schrieb jstanton8869: Got an answer on this from Leica in the UK. DOF preview works fine in AFs but not in AFC or the new iAF mode. I've tried this with my Q3 and Q2M and can confirm this is correct. "If you press Shutter Release the aperture closes and the DoF increases. But only with AFs! With AFc and iAF there is no DoF preview, because the camera always uses open aperture for refocusing. Should be the same for Q2 and Q3 (except that Q2 has no iAF)" yes, that's true - works with AFs! Link to post Share on other sites More sharing options...
MindsEye Posted June 23, 2023 Author Share #23 Posted June 23, 2023 4 hours ago, jstanton8869 said: Got an answer on this from Leica in the UK. DOF preview works fine in AFs but not in AFC or the new iAF mode. I've tried this with my Q3 and Q2M and can confirm this is correct. "If you press Shutter Release the aperture closes and the DoF increases. But only with AFs! With AFc and iAF there is no DoF preview, because the camera always uses open aperture for refocusing. Should be the same for Q2 and Q3 (except that Q2 has no iAF)" Thank you for this! Perfect timing as I was going to email my U.S. Leica contact and ask if it makes a difference which AF mode is being used. I would still prefer to have it in AFC mode. No reason not to have it even if the camera stays wide open to focus. But I suppose if it operates the same as Q2 then Leica isn't likely to change it. Still anxiously awaiting mine- I'm next on the list now 😃 Happy shooting, Joel Link to post Share on other sites More sharing options...
kirkmc Posted June 23, 2023 Share #24 Posted June 23, 2023 I got my Q3 today. I see DoF preview in iAF mode. 1 Link to post Share on other sites More sharing options...
MindsEye Posted July 2, 2023 Author Share #25 Posted July 2, 2023 On 6/23/2023 at 9:58 AM, kirkmc said: I got my Q3 today. I see DoF preview in iAF mode. Now that I finally own a Q3 I tested the DOF preview. My observation is that it only works with AFs or manual focus. When set on iAF or AFc it does not function. @kirkmc, what is your firmware version? I don't see it working in iAF mode. Thanks 2 Link to post Share on other sites More sharing options...
JNK100 Posted November 25, 2023 Share #26 Posted November 25, 2023 Of course the Q3 has DOF-preview with both manual and AF. The EVF shows what the sensor does.... 1 Link to post Share on other sites More sharing options...
Dr. G Posted November 27, 2023 Share #27 Posted November 27, 2023 Advertisement (gone after registration) On 6/11/2023 at 11:24 AM, jaapv said: Actually, DOF preview is kind of silly and useless. Your DOF will depend on the size of your print (computer screen), viewing distance and crop. What you see in the viewfinder will rarely match the final result. In macro mode it makes a bigger difference. I would find it very helpful. Link to post Share on other sites More sharing options...
jaapv Posted November 27, 2023 Share #28 Posted November 27, 2023 I never saw much difference in DOF in macro photography. . I would qualify it as narrow irrespective of aperture. Link to post Share on other sites More sharing options...
Dr. G Posted November 27, 2023 Share #29 Posted November 27, 2023 1 hour ago, jaapv said: I never saw much difference in DOF in macro photography. . I would qualify it as narrow irrespective of aperture. I’m not referring to true macro, only using macro mode on the Q3 where I need to be closer than the non-macro mode 30cm minimum focus distance. Link to post Share on other sites More sharing options...
Adammmmm Posted July 8, 2024 Share #30 Posted July 8, 2024 On 7/2/2023 at 2:08 AM, MindsEye said: Now that I finally own a Q3 I tested the DOF preview. My observation is that it only works with AFs or manual focus. When set on iAF or AFc it does not function. @kirkmc, what is your firmware version? I don't see it working in iAF mode. Thanks A year later... and I finally figured out why I can't see any difference when in iAF... 😐 Link to post Share on other sites More sharing options...
MindsEye Posted July 9, 2024 Author Share #31 Posted July 9, 2024 16 hours ago, Adammmmm said: A year later... and I finally figured out why I can't see any difference when in iAF... 😐 Glad the mystery is solved! Hopefully Leica can update the DOF preview with firmware but not holding my breath 1 Link to post Share on other sites More sharing options...
