robb Posted May 30, 2023 Share #1  Posted May 30, 2023 Advertisement (gone after registration) Can someone with experience with Rom R lenses explain the typical controls when using these lenses with the latest Leica adapter on an SL2 or SL2-s? Can you have full aperture control from the camera in all modes - PASM?  If so do you set the aperture ring to f16/22?  I was looking at an apo 100 macro, 180 summicron, or 400 2.8, in particular… thanks for explaining any limitations. Robb  Link to post Share on other sites More sharing options...
Advertisement Posted May 30, 2023 Posted May 30, 2023 Hi robb, Take a look here Using Rom R lenses with Leica Adapter on SL2?. I'm sure you'll find what you were looking for!
AZN Posted May 30, 2023 Share #2  Posted May 30, 2023 (edited) 6 hours ago, robb said: Can you have full aperture control from the camera in all modes - PASM?  If so do you set the aperture ring to f16/22?  I was looking at an apo 100 macro, 180 summicron, or 400 2.8, in particular… thanks for explaining any limitations.  The Leica L→R adapter transmits the focal length of the ROM lens and its maximum aperture.  That's all. There is no control from the camera at all.  The connection is electronic only, and even then only one-way to read the ROM chip information in the lens. Am uncertain if the R lens ROM information is used for any baked-in image correction on RAW images (like it is for some M lenses). The nice thing about the Leica L→R adapter however is that (1) it is very well made and infinty on the lens is true infinity and (2) it records the exact focal length used for the shot when using Zoom R lenses.  The latter of course won't help you much for your proposed lens selection 😃 Edited May 30, 2023 by AZN Link to post Share on other sites More sharing options...
robb Posted May 30, 2023 Author Share #3  Posted May 30, 2023 Ok.  Good to know.  It’s a shame no other aperture control from the camera is possible.  Thanks for the input. Robb Link to post Share on other sites More sharing options...
LeicaRFan Posted May 30, 2023 Share #4 Â Posted May 30, 2023 Hello Robb, i have the SL2 with the R Adapter L and the apo 100 Macro and the apo telyt r 2,8/400 non module, you can only use A or M, not P or S Programm. You see not the correct aperture in the Exif. But it make very fun to use these lenses on the SL2, an the quality is in my opinion very good ! When you have this r lenses, my advice, buy the adapter and use these unusual lenses on the SL2. Â Best regards Christian 1 Link to post Share on other sites More sharing options...
dpitt Posted May 31, 2023 Share #5 Â Posted May 31, 2023 Yes, I think the added value for the original Leica addaptors (M and R) is rather limited. Any good adapter from URTH or Novoflex or similar will do the same. There is one thing that is not mentioned yet. Even though Leica allows you to choose your lens profile (M or R ) on any adapter, it seems that the EXIF info will always show "unknown lens" no matter what on all third party adapters and it shows the chosen profile with native Leica adapters. This is IMO a cheap decision from Leica to add 'value' for their own products. Link to post Share on other sites More sharing options...
frame-it Posted May 31, 2023 Share #6  Posted May 31, 2023 (edited) On 5/30/2023 at 11:38 AM, robb said: any limitations. Robb  in theory, corrections for some lens profiles MIGHT be baked in, but not sure.   Edited May 31, 2023 by frame-it 1 Link to post Share on other sites More sharing options...
jaapv Posted May 31, 2023 Share #7  Posted May 31, 2023 Advertisement (gone after registration) Unlike M lenses, R lenses mostly do not need a corrective profile. 1 Link to post Share on other sites More sharing options...
hamey Posted May 31, 2023 Share #8  Posted May 31, 2023 I do have the Leica R to L adapter, simply it's terrific. Now with Rom lenses attached you can only use M or A. In (A) mode with Rom lenses, set your aperture manually, the camera will select the speed as well as the ISO when in Auto mode. You can also adjust the speed manually by turning the front dail, also the lens profile and IBIS is activated. In (M) mode you select the Aperture and Speed, if ISO is in Auto it will adjust to the lighting conditions. Also the lens profile and IBIS remain activated. I can truly state the my R lenses work better on my SL2-S than they ever did on my R cameras, it's the best Leica Camera that I have ever owned. Ken.  3 2 Link to post Share on other sites More sharing options...
rcusick Posted June 3, 2023 Share #9  Posted June 3, 2023 I’ve fallen in love with the R F4 zooms.  The sharpness and unique 70-90s colors are awesome. 2 Link to post Share on other sites More sharing options...
Tpau17 Posted June 3, 2023 Share #10  Posted June 3, 2023 (edited) vor 5 Stunden schrieb rcusick: I’ve fallen in love with the R F4 zooms.  The sharpness and unique 70-90s colors are awesome. yes, the old lenses are great, I use on my SL601 lenses from the 60s ( the #14372 with an lense from 1963 The color brilliance is really more than impressive for the age (wo would have  thought of digital and megapixel cameras at the time)....  Edited June 3, 2023 by Tpau17 Rechtschreibung Link to post Share on other sites More sharing options...
Eclectic Man Posted June 4, 2023 Share #11 Â Posted June 4, 2023 I can confirm that the Leica R to SL adapter does not transmit aperture information even with R-ROM lenses. 1 Link to post Share on other sites More sharing options...
