On 8/21/2025 at 12:08 PM, luetz said:
I'll keep trying..  a "Q" model that"s optimised for still photography only....no video option.
I don't see why there would be any need for a new model to eliminate the video option.  Just add a user-configurable parameter to disable video—and either gray-out or blank the video entries in the menu until the video capability was subsequently re-enabled.  This probably could be accomplished with an update to the Q3 firmware.  While I'm not privy to the current firmware code, I suspect such an on-off switch would be possible to implement without comprehensive rewriting.
Why not just not use video? I never use it and don’t see what the problem is.
vor 6 Stunden schrieb Le Chef:
I agree. But having switched to video accidentally (only) once, I would be happy if i could turn off (and on) all video-stuff in the settings in disable the swipe-to-video option this way.
A Q4 model that is equally optimised for video and stills - a do-everything camera, which is what it was designed for. At the moment it cannot do runs longer than 30 mins (not sure if that is the old legal limit for cameras, or just overheating).
I doubt that will happen - probably too difficult to engineer the Q for heat dissipation without changing it too much.
I have specialised stills cameras (analogue M, and formerly digital M) and specialised video (Blackmagic), but the Q is a small versatile camera that does everything  (with limits on both stills and video) with a high quality output.
Edited by LocalHero1953
The problem is the possibility of an errant "swipe" across the LCD switching the camera into video mode—a change that may not be immediately apparent when using the camera in bright sunlight.  This is a design bug in an otherwise rather clean menu configuration.
The only serious addition I would like is a configuration menu.
A part of the menu you set and forget, with items like video yes/no, how many frame lines, etc. In short, you select the options you want to have available as an option.
It would keep the camera free of buttons, the visible menu small, and still have the  choices you want.
43mm is for me close to perfect focal length for fixed lens camera but that lens design is not very compact (likely because OIS). So IBIS would allow to design lenses which don't have to be designed for OIS so less elements and less motors. Same would apply for 28mm. Sony and Panasonic show that IBIS can be implemented in a compact FF camera. I thought the point of the Q is a compact and light camera but it is not so much compared to the M series. So It should be ideally below 600g including battery!
One thing severely missing in any Leica but also would be useful for the Q is focus bracketing (not necessarily focus stacking because up to now the results with dedicated soft ware is vastly superior to what any brands camera can do).
Edited by 40mm f/2
Only a specialist photo-optical team of engineers could possibly know this (fewer elements and motors etc.). The exit pupil is, I understand, very close to the sensor which may preclude the use of IBIS in any case.
Which Sony and Panasonic cameras are you referring to ?
I had the Q43. Thought it was the perfect camera, yet I sold it to fund another system. If I ever go on a long trip by foot, I might buy another one, but as I am traveling by car, I always take at least two cameras.
What I missed on the Q, and any other Leica, is to make long exposures in a convenient way. So, this I would like to see on a Q4. Together with a tiltable screen in portrait mode.
It might be possible to add focus-bracketing to the current Q3 models by modifying their firmware.
Agreed, that is a problem. It is a always a risk when the LCD is active, such as when shooting with the screen flipped out. There should be a way to fully disable the accidental swipe to video.
Sony A7CR and Lumix S9. Where the exit pupil is depends on lens design, not having OIS reduces the design restrictions caused by having compensating lens elements (lateral shift). Not a big issue to have that space in a long tele lens (and the extra motors) but for a compact wide to normal lens OIS definitely increases volume, weight and lens complexity.
Edited by 40mm f/2
Yes of course OIS will add some weight and volume.
The Sony with a comparable lens and EVF would not be any smaller and lighter I don't think .
The S9 doesn't have an EVF so is in no way comparable. One cannot compare apples to pears. A comparable lens to the Q3 28mm would not be small and light either.
You are IMO correct about size.  The closest Sony lens would likely be https://www.mcbaincamera.com/productdetail.php?mcbain_id=0231630
On an A7CR it would be about the same size as a Q.
Simplified Menu for items that do not pertain to Still Photography....
