I decided to test the accuracy of my MP. so I shot a roll of fuji superia 400 (USA) on an overcast day and took 3 frames/shots per shutter speed and adjusted the aperture based on shutter speed for correct exposure.
The results:
1/1000, 1/125 and below are all consistent; however 1/500 and 1/250 have a green cast to the shadows. I am not sure if this is due to inaccuracy of the 1/500 & 1/250 speed and was wondering if this looks like a stop or more under exposed? I know that the tolerance could be 1/3 +/- of faster speeds but I am not sure if 1/3 stops are differentiable?
First picture is over all picture and second picture is centre crop
All pictures on the left is 1/125 @ f8 while pictures on the right is 1/250 @ f5.6
Edited by 69xchange
Top right corner crop
On 4/19/2023 at 10:11 AM, Huss said:
You cannot test the accuracy of your shutter by shooting a colour negative film that has very wide exposure latitude.
Hmm, but based on the negatives wouldn’t this show that frame 8 is a bit thinner than frame 9? Both shot at correct exposure but frame 8 is 1/250 f/5.8 while frame 9 is 1/125 f/8.
My question is does this look like 1 stop exposure difference or within tolerance?
Edited by 69xchange
Film camera shutter speeds have a fairly loose tolerance, so the small variation in exposure you show doesn't look too bad to me. One speed might be to the + tolerance and the other to the - tolerance.
For example, it's common for a Leica cloth shutter to have a 1/1000 shutter speed test  more like 1/700 after some use.
Thats probably 1/10 a stop difference, which is completely irrelevant. Just adjust the image to taste in processing.
You can't get absolute precision with a mechanical controlled cloth shutter like this one. But so far my pictures werden t affected by that if i have done my part correctly. Don' t think to much about that, go out and use your lovely camera.
Everything fine!
  • 2 weeks later...
It's long ago that I did experimental physics, but I think that the set-up for testing the accuracy of the shutter is wrong. It depends on your  assumption that the  aperture of your lens has a highly precise step  from 5,6 to 8.    The aperture error  should at least  be 2, better 3 orders ( Größenordnungen) less than the parameter you want to measure.
