When using my Leica MP recently, I found that the shutter dial is loose in the middle of 1/50-1/60, and the shutter dial is not fixed, which annoys me a lot. Has anyone encountered this same problem?
Mainly I want to figure out if this looseness affects my shutter speed and the actual use of 1/50 shutter speed
2 minutes ago, 250swb said:
我从你的视频中看不到,但你的意思是在 1/30 和 1/60 之间没有制动器?如果是这种情况,则您的相机有问题。
Sorry, that's not what I meant, I meant that there is a small distance from 1/50-1/60 that it is loose.
