jdlaing Posted April 13, 2023 Share #21 Posted April 13, 2023 Advertisement (gone after registration) 16 minutes ago, Photoworks said: not sure how you read it in texas, but over at leicaof the base native ISO of M11 is 64 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! The way I read it in Texas is native iso wasn’t the original question. Link to post Share on other sites More sharing options...
Advertisement Posted April 13, 2023 Posted April 13, 2023 Hi jdlaing, Take a look here Is ISO 64 on M11 a Pull ISO? . I'm sure you'll find what you were looking for!
jdlaing Posted April 13, 2023 Share #22 Posted April 13, 2023 38 minutes ago, SrMi said: Sorry, M11 has only one native ISO, the base ISO. Almost all photo cameras have only one native ISO. Dual native ISOs are typically implemented in video cameras. Native iso and base iso are different. Link to post Share on other sites More sharing options...
Photoworks Posted April 13, 2023 Share #23 Posted April 13, 2023 8 minutes ago, jdlaing said: The way I read it in Texas is native iso wasn’t the original question. you are trying to be funny, I appreciate that. But PULLing my leg doesn't change the outcome to PULL! well there is no PULL on the M11, ISO 64 is the base iso and native iso. ISO 64 gives maximal dynamic range, which is not the case in most pulled cameras. Link to post Share on other sites More sharing options...
Guest Posted April 13, 2023 Share #24 Posted April 13, 2023 1 hour ago, jdlaing said: Native iso and base iso are different. If you find yourself in a hole, stop digging. The world and its dog knows the base ISO is 64. Link to post Share on other sites More sharing options...
SrMi Posted April 13, 2023 Share #25 Posted April 13, 2023 (edited) 1 hour ago, jdlaing said: Native iso and base iso are different. So what are they? Neither term has any real meaning. Here is the answer from a guy who is very knowledgeable: https://www.dpreview.com/forums/post/65455206 Excerpts: 'Base ISO' simply means the lowest ISO that the manufacturer has decided is within the main range of ISOs. There is really no such thing as 'native ISO'. A sensor does not have an ISO. Edited April 13, 2023 by SrMi Link to post Share on other sites More sharing options...
Adam Bonn Posted April 13, 2023 Share #26 Posted April 13, 2023 I think this is just a confusion spectre from the original M10/p/d Which as I’m sure you’ll all recall was originally touted as 100, then Auto ISO was tweaked via FW to prevent it selecting 100 (as it was actually a pull), then various folk have suggested various values for the actual base ISO of the M10, but they’re all irrelevant because the user can’t select ranges between 100-200 anyway Then the sensor test sites suggested that the most DR was to be had at 100… but this muddied the waters because DR and exposure latitude aren’t the same thing… Then Leica didn’t repeat that little semi-shambles again and the M10R/M0M/M11 all have user selectable base ISO values of 100/160/64 respectively Link to post Share on other sites More sharing options...
Huss Posted April 13, 2023 Share #27 Posted April 13, 2023 Advertisement (gone after registration) What’s the base ISO of the new M6? 1 3 Link to post Share on other sites More sharing options...
Banned 103051 Posted May 25, 2023 Share #28 Posted May 25, 2023 On 4/12/2023 at 2:48 PM, chm said: M10's Base ISO started at 200 Is ISO 64 in M11 a Pull ISO or a Base ISO? yes. The M11’s base ISO is in fact 64. You don’t have to manually select this setting. If set to auto the camera will choose it on its own. Link to post Share on other sites More sharing options...
Tailwagger Posted June 2, 2023 Share #29 Posted June 2, 2023 ...and IIRC was touted as a point of pride at the time of the M11's intro. Link to post Share on other sites More sharing options...
j453 Posted June 2, 2023 Share #30 Posted June 2, 2023 Am 13.4.2023 um 01:47 schrieb jdlaing: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Just read the full article, especially if you post and post and post and post and post.... This was clearly announcing the specs for of the M11 Mono, M11 without color filter array. Link to post Share on other sites More sharing options...
Antonio Russell Posted June 3, 2023 Share #31 Posted June 3, 2023 https://www.dxomark.com/leica-m11-sensor-test/ 1 Link to post Share on other sites More sharing options...
LBJ2 Posted June 4, 2023 Share #32 Posted June 4, 2023 On 4/12/2023 at 7:41 AM, jdlaing said: Pull Not 😎 Link to post Share on other sites More sharing options...
wizard Posted June 13, 2023 Share #33 Posted June 13, 2023 Am 14.4.2023 um 01:29 schrieb Huss: What’s the base ISO of the new M6? The new M6 is a very advanced camera, it has user selectable base ISO 😉. 1 4 Link to post Share on other sites More sharing options...
