Panda428 Posted March 21, 2023 Share #1 Posted March 21, 2023 Advertisement (gone after registration) Hi everyone as a newbie of Leica M world, new ‘issues’ coming up 😄 Wondering if you guys can help me out of this. So basicly I bought a voigtlander 28mm f2 type II, found something after I mounted it on my M8. 1. when I turn the focus ring between the range of 0.5-0.6 meter, the focusing patch will not move, it starts moving after 0.6 meter. 2.as long as I mounted this lens, the frame line lever will no longer movable, is that normal? thank you guys! from a Leica freshman 😄 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/373938-%E2%80%98issues%E2%80%99-after-i-mounted-voigtlander-28mm-lens/?do=findComment&comment=4732621'>More sharing options...
Advertisement Posted March 21, 2023 Posted March 21, 2023 Hi Panda428, Take a look here ‘Issues’ after I mounted voigtlander 28mm lens . I'm sure you'll find what you were looking for!
Guest Posted March 21, 2023 Share #2 Posted March 21, 2023 Rangefinder minimum focus distance is 0.7m - this is a limitation of the mechanism in the camera, not the lens. Link to post Share on other sites More sharing options...
Panda428 Posted March 21, 2023 Author Share #3 Posted March 21, 2023 36 minutes ago, mzbe said: Rangefinder minimum focus distance is 0.7m - this is a limitation of the mechanism in the camera, not the lens. No wonder! Thank you so much for the info, definitely need more to learn! Link to post Share on other sites More sharing options...
250swb Posted March 26, 2023 Share #4 Posted March 26, 2023 On 3/21/2023 at 8:01 PM, Panda428 said: Hi everyone as a newbie of Leica M world, new ‘issues’ coming up 😄 Wondering if you guys can help me out of this. So basicly I bought a voigtlander 28mm f2 type II, found something after I mounted it on my M8. 1. when I turn the focus ring between the range of 0.5-0.6 meter, the focusing patch will not move, it starts moving after 0.6 meter. 2.as long as I mounted this lens, the frame line lever will no longer movable, is that normal? thank you guys! from a Leica freshman 😄 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! And as for the fame lever not working I think the problem is you kept your finger on the lens release button while mounting the lens, this causes it to rotate past centre and not engage properly with the frame line ‘switch’. Let the lens click into place on its own. Link to post Share on other sites More sharing options...
rivi1969 Posted March 27, 2023 Share #5 Posted March 27, 2023 On 3/21/2023 at 2:43 PM, Panda428 said: No wonder! Thank you so much for the info, definitely need more to learn! beautiful lens, I really want one in black paint for my M8 Link to post Share on other sites More sharing options...
Greenhilltony Posted June 11, 2023 Share #6 Posted June 11, 2023 On 3/22/2023 at 4:05 AM, mzbe said: Rangefinder minimum focus distance is 0.7m - this is a limitation of the mechanism in the camera, not the lens. Not 0.7m anymore from M10. The M10 is capable of closing to 0.6m. Link to post Share on other sites More sharing options...
a.noctilux Posted June 11, 2023 Share #7 Posted June 11, 2023 Advertisement (gone after registration) 2 hours ago, Greenhilltony said: Not 0.7m anymore from M10. The M10 is capable of closing to 0.6m. We are talking about M8. I use happily for years my M8's RF to 48cm with DR Summicron + SDPOO. Even if this lens is not M8 compatible, it's useable with the goggles as usual, RF from 90cm to 48cm. Without SDPOO, RF focus to about 10m. Mounting this DR lens can be done ( mandatory ! ) when I set the focus ring to about 1.5m. Link to post Share on other sites More sharing options...
fabianoliver Posted July 9, 2023 Share #8 Posted July 9, 2023 i'm seduced by this Voigtlander lens, can you upload some pictures, just to see how it renders on the M8? thanks! Link to post Share on other sites More sharing options...
ManSter420 Posted July 9, 2024 Share #9 Posted July 9, 2024 On 3/21/2023 at 3:01 PM, Panda428 said: Hi everyone as a newbie of Leica M world, new ‘issues’ coming up 😄 Wondering if you guys can help me out of this. So basicly I bought a voigtlander 28mm f2 type II, found something after I mounted it on my M8. 1. when I turn the focus ring between the range of 0.5-0.6 meter, the focusing patch will not move, it starts moving after 0.6 meter. 2.as long as I mounted this lens, the frame line lever will no longer movable, is that normal? thank you guys! from a Leica freshman 😄 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! have the same lens for wide angle and found this one. Wonderful lens for its price 100% and 0.5~0.6m works good with visoflex2 on my M11 Link to post Share on other sites More sharing options...
