My go-to rubber fixer is a "Silicone Gun And Reel Cloth". I haven't tried it on the Summarit rubber, mine isn't oxidized. But I've used it on my old Minolta and Canon rubber. Brings it back to life. Works on metal and leather too.
Edited by thatkatmat
With 209 views to date, but only 2 suggested fixes, it appears a lot of people are interested in ideas, but don't have  a solution to recommend. My local camera store, being an authorized Leica dealer, does not know of a photography-related product, and told me to instead try the automotive application "Armor All" that refreshes car interiors' plastic trim. However, as I've previously used a small dab of automotive tire black foam, with great success, that's what I may use again. Just enough on a Q-tip to restore a lens' rubber to look as new.
Armor All products leave sort of a shiny finish with greasy feel that you might not find suitable.  I haven’t used this on a Summarit rubber focus grip, but if you’re looking for an automotive application with a matte finish and no greasy residue, I’d recommend Griot’s Garage Vinyl & Rubber dressing or Interior Cleaner, which should be readily available on Jeff Bezos’ marketplace or your local auto parts store.
Avoid any ‘back to black’ products for the same reasons good car retailers avoid them, they add a coating that masks the problem but degrades again over time. Try simply cleaning the grip with white spirit.
Edited by 250swb
I've had zero issues using Meguiars Ultimate Black Restorer. Applied to various lenses' focusing rings and the rubber grip part of my Xpan2 which had turned that milky grey, still looks like new years later.
Edited by Huss
What many of those products do is bond with the rubber and it builds up in the low lying areas if it is reapplied due to wear on the high points, and can even look fake and ugly after a while given that rubber is never a perfect black. That is why good car detailers working to concours standard don't use them. But it's a similar type of plasticisers that are coming out of the rubber as on the notorious back covering of an old Nikon F100, and once these are removed and not cosmetically coated over the problem is solved for many years to come, and the rubber remains looking like rubber.
  • 4 weeks later...
Another lens I turned from milky grey to black in about 2 minutes using Meguiars Ultimate Black.
Dry, non greasy to the touch.  And I expect it to stay like this for years, just as all my other lenses that I have treated this with. With zero issues.
