Zeiss 18 Distagon Question
atufte
You'll be lucky! Mine was made about 50 years ago by a British company called Moore and Wright that I don't know if it even exists any more. I have never seen another one. Mine is out on loan against a fat deposit cheque at the moment, since I have no need of it on my medical tourism trip to South Africa. No return of torque driver - cheque gets cashed!
Wilson
Figures...<G> That would be a nice tool to have.
Cheers,
Sean
  • Replies 83
  • Created
  • Last Reply
Mine is from Wiha, another great German manufacturer of precision tools.
England / Home - Wiha | Screwdrivers L-Keys Bits Pliers Online Shop| Premium Tools for Professionals
You'll even see on this web-site home page one being used to remove the bayonet ring off a lens. Can't identify it though, has A-M focus switch, so not Leica...
JMs adapter arrived today, successfully mounted it after unscrewing the Zeiss adapter using acetone, a Wiha PicoFinish 260P screwdriver which fitted perfectly, using the techniques recommended by Sean and Wilson on carefully unscrewing and applying acetone (had to buy half a liter!) with Q-tips step by step, and applying small amounts of Loctite when fastening the JM adapter.
After some nail polishing - Voila - the Zeiss comes up as a WATE, and I use the menu to set it as a 18mm. I use a Heliopan ES58 UV/IR that fits perfectly, not step up/down.
I have to wait for the weekend to test it however, up here in Norway daylight is already gone when back from work this time of the year....
