Ne314satel Posted November 6, 2022 Share #21 Posted November 6, 2022 Advertisement (gone after registration) On 11/4/2022 at 10:19 PM, mujk said: Practically all original M9 sensors and also those replaced before the cause for sensor corrosion was found and remedied (approx. autumn 2015) will eventually develop sensor corrosion. The camera may also become useless because of some other fault requiring replacement of parts no longer available. There seems to be a lot of hype regarding M9 image quality, driving used prices up. The M9 is a great camera, but because of the mentioned serviceability issues I would not pay very much for one, at least not for one without a post-autumn 2015 replaced sensor. Hi. I have a m9-p from 2010. The sensor is without corrosion and has not changed. Everything works well) Link to post Share on other sites More sharing options...
Advertisement Posted November 6, 2022 Posted November 6, 2022 Hi Ne314satel, Take a look here Leica M9P with original CCD 13 still worth?. I'm sure you'll find what you were looking for!
mujk Posted November 6, 2022 Share #22 Posted November 6, 2022 3 hours ago, Ne314satel said: Hi. I have a m9-p from 2010. The sensor is without corrosion and has not changed. Everything works well) If I understand it correctly environmental factors (humidity) may play a role, but over time the risk of sensor corrosion, or more exactly sensor coating detaching, increases. In my M9 it appeared when it was about 7 years old. Not very visible, but fortunately I detected it at an early stage and just in time to get the free sensor replacement. Any M9 that does not have this issue (yet) has great user value for its owner, but cameras with the original sensor should be less valuable than those with a replaced one when sold. Link to post Share on other sites More sharing options...
Luke_Miller Posted November 7, 2022 Share #23 Posted November 7, 2022 (edited) 17 hours ago, mujk said: Any M9 that does not have this issue (yet) has great user value for its owner, but cameras with the original sensor should be less valuable than those with a replaced one when sold. I figure my Leica repair invoice showing redesigned sensor replacement on my M9M is probably worth at least $1000 US on resale. Edited November 7, 2022 by Luke_Miller Link to post Share on other sites More sharing options...
TomB_tx Posted November 7, 2022 Share #24 Posted November 7, 2022 On 11/6/2022 at 2:31 PM, mujk said: In my M9 it appeared when it was about 7 years old. Not very visible, but fortunately I detected it at an early stage and just in time to get the free sensor replacement. Exactly the same for me. Link to post Share on other sites More sharing options...
dlw Posted November 11, 2022 Share #25 Posted November 11, 2022 I have an M9-P and the sensor glass only started separating two months ago. I had Kolari Vision do the replacement with Schott BG-39 glass and the results are fine. I called Kolari before sending it in and discussed all the options and disaster scenarios and felt they were perfectly capable. I would recommend their service without hesitation. You can view a DNG & JPG from the repaired camera: Sample DNG & JPG Link to post Share on other sites More sharing options...
