The lens resolution/ sensor resolution is not a weakest link situation but an additive one. Your lens will work better than ever. The lens correction by the coding is minimal to zero.
  • Thanks 4
It is a common misconception to think of sensors out-resolving lenses or lenses out-resolving sensors. But the lens-and-sensor system doesn't work that way.
Better lenses yield better images on any sensor. And higher-resolving sensors yield better images behind any lens. So don't worry. If you liked your 50 mm Summicron in the past then you will love it on the M11.
  • Thanks 3
