Thatch2021 Posted October 10, 2022 Share #1 Posted October 10, 2022 Advertisement (gone after registration) Hello, I have a quick question. I have searched online and the manual but can't figure out how to set the Q2 so I can utilize a 1/8000s shutter speed. The manual says to use Extended Electronic Shutter and you can get up to 1/40000s shutter. What other settings do I need to be aware of for this to be available? Current Camera settings: ISO 1600, F/4, electronic shutter = extended. Thanks, Thatch2021 Link to post Share on other sites More sharing options...
Advertisement Posted October 10, 2022 Posted October 10, 2022 Hi Thatch2021, Take a look here Camera settings for high shutter speeds 1/8000s . I'm sure you'll find what you were looking for!
Ba Erv Posted October 10, 2022 Share #2 Posted October 10, 2022 Set the Shutter Speed dial to 1/2000 then tap the Menu Button. Tap on the Shutter Speed box on the screen then either adjust the slider or use the rocker switch to set the desired shutter speed up to 1/40000. 2 Link to post Share on other sites More sharing options...
Thatch2021 Posted October 10, 2022 Author Share #3 Posted October 10, 2022 16 minutes ago, Ba Erv said: Set the Shutter Speed dial to 1/2000 then tap the Menu Button. Tap on the Shutter Speed box on the screen then either adjust the slider or use the rocker switch to set the desired shutter speed up to 1/40000. I will give it a try thank you!! 1 Link to post Share on other sites More sharing options...
M11 for me Posted October 11, 2022 Share #4 Posted October 11, 2022 Go into Menu page 2 and select the "eoectronic shutter". Set it to "extended". That is what you described in your post 1. Now when you have set your speed dial to "a" (automatic) then the camera chooses up to 1/40'000s. Do not worry about that anymore. When you are in shutter speed priority (speed dial NOT on "a") or in full manual mode then you have to choose your shutter speed above 1/2000s as described in post 2. Link to post Share on other sites More sharing options...
Lucena Posted October 19, 2022 Share #5 Posted October 19, 2022 (edited) On 10/10/2022 at 10:41 PM, Ba Erv said: Set the Shutter Speed dial to 1/2000 then tap the Menu Button. Tap on the Shutter Speed box on the screen then either adjust the slider or use the rocker switch to set the desired shutter speed up to 1/40000. Stupid me who never read the manual! Could have avoided the purchase of the ND filter 🤪 Thanks for the info, it changes my life. Edited October 19, 2022 by Lucena 1 Link to post Share on other sites More sharing options...
Siriusone59 Posted October 19, 2022 Share #6 Posted October 19, 2022 3 hours ago, Lucena said: Stupid me who never read the manual! Could have avoided the purchase of the ND filter 🤪 Thanks for the info, it changes my life. Nothing stupid about that, never know when you might need to photograph a waterfall or stream.🙂 1 Link to post Share on other sites More sharing options...
