Monochrome Posted September 22, 2022 Share #1 Posted September 22, 2022 Advertisement (gone after registration) I recently found an issue with my shutter time wheel. When i try to change the setting from “A” to a manual speed or vice versa, the actual setting is different then the one indicated on the wheel. For instance, if i turn the wheel from “A” to 1/250 sec it might actually be on 1/2000 sec. The only way to know that is by checking the info on the LCD. Then, if i try to go back to “A”, it might be on a manual setting of 1/2 sec. Only after long turning back and forth i can get back to “A”, by luck. I tried taking out the battery and CF card, and also a reset but nothing works. Is anyone familiar with this problem? I updated to the latest firmware in may, but didn’t notice it because i normally like to work in the semi automatic “A” setting. Monochrome Link to post Share on other sites More sharing options...
Advertisement Posted September 22, 2022 Posted September 22, 2022 Hi Monochrome, Take a look here M-262 shutter wheel. I'm sure you'll find what you were looking for!
lct Posted September 25, 2022 Share #2 Posted September 25, 2022 On 9/22/2022 at 12:45 PM, Monochrome said: I recently found an issue with my shutter time wheel. When i try to change the setting from “A” to a manual speed or vice versa, the actual setting is different then the one indicated on the wheel. For instance, if i turn the wheel from “A” to 1/250 sec it might actually be on 1/2000 sec. The only way to know that is by checking the info on the LCD. Then, if i try to go back to “A”, it might be on a manual setting of 1/2 sec. Only after long turning back and forth i can get back to “A”, by luck. I tried taking out the battery and CF card, and also a reset but nothing works. Is anyone familiar with this problem? I updated to the latest firmware in may, but didn’t notice it because i normally like to work in the semi automatic “A” setting. Monochrome You may wish to disable auto iso if any. Link to post Share on other sites More sharing options...
Casey Jefferson Posted September 25, 2022 Share #3 Posted September 25, 2022 Leica M while well built it isn't indestructible, I replaced the back dial on mine recently. It's a pretty old camera by now so parts do wear out. Send it to Leica for a check up, here in Singapore Leica staff actually expressed that dials may not need to be replaced as they'll attempt to clean it first and sometimes that's all it need. Link to post Share on other sites More sharing options...
Monochrome Posted October 1, 2022 Author Share #4 Posted October 1, 2022 Thank you. I might just do that. Link to post Share on other sites More sharing options...
