Jerry Attrik Posted August 24, 2022 Share #1 Â Posted August 24, 2022 Advertisement (gone after registration) Did Leitz, or anyone, make a shoe mount direct vision viewfinder for a 280mm. lens? Link to post Share on other sites More sharing options...
Advertisement Posted August 24, 2022 Posted August 24, 2022 Hi Jerry Attrik, Take a look here Viewfinders for r.f. cameras. I'm sure you'll find what you were looking for!
earleygallery Posted August 24, 2022 Share #2 Â Posted August 24, 2022 Not that I'm aware of. The problem will be parralax compensation. If you need to use a 280mm lens you really need an SLR (or visoflex). Link to post Share on other sites More sharing options...
Michael Geschlecht Posted August 25, 2022 Share #3 Â Posted August 25, 2022 (edited) Hello Jerry, Leitz made a sports finder for the 200 mm lens. First called SFTOO when introduced & later called 12035 when letter codes were replaced with numbers. There is also a SQTOO for 400mm lenses. Later changed to 12037. Both require extension tube TZFOO which was later coded 14077Q if you are not using a MECHANICAL Visoflex I between the lens & the camera body. A Visoflex I has the appropriate mounting shoe. This tube TZFOO/14077Q, which the finders attach to, has a special shoe for the finders. There does not seem to be an equivalent finder for a 280mm lens. Altho you could figure out the parameters for using a 280mm lens if you used the 200mm finder. 1 problem with using finders like these, which is sometimes also a problem with other finders & MC, MR & MR4 meters, etc,. is that the finders/meters must have their feet properly adjusted & aligned so that the finders/meters are aimed properly. Which also means choosing a distance to align them at. I use Infinity. Best Regards, Michael Edited August 25, 2022 by Michael Geschlecht Link to post Share on other sites More sharing options...
250swb Posted August 25, 2022 Share #4 Â Posted August 25, 2022 Komura made a 2x teleconverter outfit for both LTM and M mounts that came with an adjustable shoe mounted viewfinder with the longest focal length at 270mm (135mm lens x2). I had one and to be honest the image quality wasn't very good, nor the accuracy of the viewfinder at such great distances, but once upon a time it was a valid option. 1 Link to post Share on other sites More sharing options...
Jerry Attrik Posted August 28, 2022 Author Share #5  Posted August 28, 2022 (edited) Thank you all. You have amply confirmed my thoughts. I did, at one time, have a Komura reflex housing. Not the best attempt at a Visoflex copy. The prism was held by a piece of plastic sponge and it rotted the silvering away.  Many thanks to you D. Lox. Edited August 28, 2022 by Jerry Attrik Link to post Share on other sites More sharing options...
250swb Posted August 28, 2022 Share #6  Posted August 28, 2022 36 minutes ago, Jerry Attrik said: Thank you all. You have amply confirmed my thoughts. I did, at one time, have a Komura reflex housing. Not the best attempt at a Visoflex copy. The prism was held by a piece of plastic sponge and it rotted the silvering away.  Many thanks to you D. Lox. The Komura teleconverter is not a reflex housing, it is a dedicated teleconverter kit, the viewfinder itself is a nice piece of equipment and beautifully made if a bit low contrast, but the optics in the 2x teleconverter don't match the quality of a Leica lens, this is what lets it down for a modern audience. Link to post Share on other sites More sharing options...
Jerry Attrik Posted August 30, 2022 Author Share #7  Posted August 30, 2022 (edited) Advertisement (gone after registration) Sorry to have to tell you this, 250SWB; but the gadget which I have, and have had for many years, about fifty, is really a Komura reflex housing. This is the name embossed in the lens port cover. It does not look like a tele-converter but, with a bit of a squint of the eye on a dull foggy day, it can give a very good impression of an early screw fit Visoflex 2. I hope that your doubt concerning its authenticity is not an indication of extreme rarity and value. At the moment it is no more than a collection of tiny screws and odd pieces of metal jumbled together in a polythene bag. One day, about 35 years, ago I was going to re-build it until I discovered the corroded silvering and rotted plastic foam. I may yet have buy "the real thing"! All the best D. Lox Edited August 30, 2022 by Jerry Attrik pressed <ctrl> instead of <shift> Link to post Share on other sites More sharing options...
250swb Posted August 31, 2022 Share #8  Posted August 31, 2022 (edited) On 8/24/2022 at 9:57 PM, Jerry Attrik said: Did Leitz, or anyone, make a shoe mount direct vision viewfinder for a 280mm. lens?  21 hours ago, Jerry Attrik said: Sorry to have to tell you this, 250SWB; but the gadget which I have, and have had for many years, about fifty, is really a Komura reflex housing. This is the name embossed in the lens port cover. It does not look like a tele-converter but, with a bit of a squint of the eye on a dull foggy day, it can give a very good impression of an early screw fit Visoflex 2. I hope that your doubt concerning its authenticity is not an indication of extreme rarity and value. At the moment it is no more than a collection of tiny screws and odd pieces of metal jumbled together in a polythene bag. One day, about 35 years, ago I was going to re-build it until I discovered the corroded silvering and rotted plastic foam. I may yet have buy "the real thing"! All the best D. Lox You asked about a shoe mounted direct vision viewfinder for a 280mm lens, a reflex housing is not a direct vision viewfinder it uses mirrors. You also seem to have gone from once having had a Komura reflex housing (post #5) to having a Komura reflex housing (post #7) so the confusion is on your side. I do not doubt the reflex housing exists as a product once made by Komura, it was yourself that went off on a tangent (post #5) that triggered my response by way of clarification of my previous post regarding the teleconverter and its accompanying direct vision viewfinder.  Edited August 31, 2022 by 250swb Link to post Share on other sites More sharing options...
