tm art Posted August 2, 2022 Share #1 Posted August 2, 2022 Advertisement (gone after registration) A couple months ago the screen on my X-Vario did not light up when I turned the camera on. It was as dark as when the camera is switched off. I removed the battery and put it back in and it seemed to work normally after that. Recently, however, it has started happening more often, and several times I haven't been able to make the screen display work. It appears that the focusing, exposure metering, shutter etc are not affected. I took some pictures by just aiming the camera at the subject and they look fine. I don't think it has to do with the battery-fully charged or low charge has made no difference. The camera was not much used and has been very well cared for. Right now the screen is working again, but for how long? Has anybody had this problem? Quote Link to post Share on other sites More sharing options...
Advertisement Posted August 2, 2022 Posted August 2, 2022 Hi tm art, Take a look here X-Vario screen display - serious problem. I'm sure you'll find what you were looking for!
wda Posted August 2, 2022 Share #2 Posted August 2, 2022 If you have an optional EVF, does that work consistently? I have not experienced your problem, neither can I recall a case reported here. Quote Link to post Share on other sites More sharing options...
tm art Posted August 2, 2022 Author Share #3 Posted August 2, 2022 37 minutes ago, wda said: If you have an optional EVF, does that work consistently? I have not experienced your problem, neither can I recall a case reported here. Thanks. I do have the evf and will try to see if it works once I return from my trip. Indeed I searched for "Screen" in topic titles on this forum and nothing came up so I assume it's not a common issue. 1 Quote Link to post Share on other sites More sharing options...
jaapv Posted August 2, 2022 Share #4 Posted August 2, 2022 Could well be a bad contact on a flex inside - an easy repair. Quote Link to post Share on other sites More sharing options...
tm art Posted August 3, 2022 Author Share #5 Posted August 3, 2022 Thanks. I thought about a bad contact too since it doesn't seem to have a pattern. Quote Link to post Share on other sites More sharing options...
dkCambridgeshire Posted August 4, 2022 Share #6 Posted August 4, 2022 On 8/2/2022 at 11:40 PM, jaapv said: Could well be a bad contact on a flex inside - an easy repair. But ... Leica Camera no longer offer support or repairs for any X series camera and independent service agencies might not be willing to investigate. OP have you tried using a different SD card — and preferably a well known established brand? 1 Quote Link to post Share on other sites More sharing options...
jaapv Posted August 4, 2022 Share #7 Posted August 4, 2022 Advertisement (gone after registration) Leica Wetzlar might on special request Quote Link to post Share on other sites More sharing options...
tm art Posted August 5, 2022 Author Share #8 Posted August 5, 2022 On 8/4/2022 at 5:15 PM, dkCambridgeshire said: But ... Leica Camera no longer offer support or repairs for any X series camera and independent service agencies might not be willing to investigate. OP have you tried using a different SD card — and preferably a well known established brand? I'll give it a try next time the problem happens. Current card is SanDisk Extreme Pro 64GB. I have a 2GB same brand as a backup. Thanks Quote Link to post Share on other sites More sharing options...
tm art Posted August 5, 2022 Author Share #9 Posted August 5, 2022 On 8/4/2022 at 6:04 PM, jaapv said: Leica Wetzlar might on special request Good to know, thanks. It may well cost more than what I paid for the camera though Quote Link to post Share on other sites More sharing options...
dkCambridgeshire Posted August 10, 2022 Share #10 Posted August 10, 2022 Try resetting all menu settings to factory defaults. Select 'User Profile' and then 'Default profile'. 1 Quote Link to post Share on other sites More sharing options...
tm art Posted August 15, 2022 Author Share #11 Posted August 15, 2022 On 8/10/2022 at 5:45 AM, dkCambridgeshire said: Try resetting all menu settings to factory defaults. Select 'User Profile' and then 'Default profile'. Worth trying, thanks. If that cured the problem (currently the camera works fine) would changing back to my current setting options restart the problem? Quote Link to post Share on other sites More sharing options...
dkCambridgeshire Posted August 17, 2022 Share #12 Posted August 17, 2022 On 8/15/2022 at 10:43 PM, tm art said: Worth trying, thanks. If that cured the problem (currently the camera works fine) would changing back to my current setting options restart the problem? No guarantee it will remedy the problem but worth a try. If it does work than any subsequent resetting should not resurrect the same problem. 1 Quote Link to post Share on other sites More sharing options...
TMorita Posted August 29, 2022 Share #13 Posted August 29, 2022 Have you tried a new battery? 1 Quote Link to post Share on other sites More sharing options...
tm art Posted August 29, 2022 Author Share #14 Posted August 29, 2022 6 hours ago, TMorita said: Have you tried a new battery? Thanks. You mean a brand new one? At one point I did swap the battery I was using with the other one fully charged. Both batteries came with the camera when I bought it second hand Quote Link to post Share on other sites More sharing options...
wda Posted August 29, 2022 Share #15 Posted August 29, 2022 (edited) 1 hour ago, tm art said: Thanks. You mean a brand new one? At one point I did swap the battery I was using with the other one fully charged. Both batteries came with the camera when I bought it second hand I would treat them both as suspect. Even if genuine Leica stock, they could be unreliable by now. I would source a fresh one. Edited August 29, 2022 by wda 1 Quote Link to post Share on other sites More sharing options...
tm art Posted August 29, 2022 Author Share #16 Posted August 29, 2022 44 minutes ago, wda said: I would treat them both as suspect. Even if genuine Leica stock, they could be unreliable by now. I would source a fresh one. Interesting. I know little about batteries, didn't know they may cause such issues. The ones I have are probably used as little as the camera, and they last a long time after fully charged (they appear to hold a charge well) 1 Quote Link to post Share on other sites More sharing options...
