69xchange Posted July 19, 2022 Share #1 Posted July 19, 2022 Advertisement (gone after registration) I just picked up a 35mm summicron asph v2 (w/ metal lens hood)and notice that the lens hood doesn’t screw on all the way smoothly. The initial threading and turning is fine but once it gets near the end (about 90 degree rotation remaining) it requires quite a bit of force to tighten it so the dot on the lens hood lines up with the selected aperture. for example if the aperture is selected at f2, the resistance for screwing the lens hood on starts when the dot of the lens hood is around f16. is anyone else’s35mm summicron asph v2 similar or should it screw in all the way normally with a flick of a finger? thanks Link to post Share on other sites More sharing options...
Advertisement Posted July 19, 2022 Posted July 19, 2022 Hi 69xchange, Take a look here 35mm summicron ASPH v2 lens hood issue. I'm sure you'll find what you were looking for!
jakontil Posted July 20, 2022 Share #2 Posted July 20, 2022 I remember the Q hood also need a little bit of force when tightening up at the end of the thread i might be the same case? Link to post Share on other sites More sharing options...
poli Posted July 20, 2022 Share #3 Posted July 20, 2022 My summicron also requires quite a bit mod force to turn it all the way. Same as my q2 and super elmar 24. Si I guess it is normal. Link to post Share on other sites More sharing options...
Frekeman Posted July 20, 2022 Share #4 Posted July 20, 2022 I've got the Summicron 35mm ASPH v2 and also the Elmarit 28mm ASPH v2 which both share the same type of hood. Towards the end when screwing on the hoods on both lenses it gets a bit tighter and I think it's a part of the design to ensure the hoods stick to where they should be. I would not say that I need to use a "bit of force" but that's of course relative. The extra tightness feels just right. Best, Fred Link to post Share on other sites More sharing options...
