Mikko Kankainen Posted June 29, 2022 Share #1 Posted June 29, 2022 Advertisement (gone after registration) I tried to search but couldn't find another post. I bought for 200€ Voigtländer 15mm L39 version that is suppose to give purple corners with digital cameras. I thought that if this in indeed the case I will use it with my M4. However this lens performs great, no purple corners, just vignetting that is easy to correct, I use Voightlander 15mm II profile in Lightroom. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 8 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/334012-voigtl%C3%A4nder-15mm-l39-first-version-with-leica-m11/?do=findComment&comment=4462098'>More sharing options...
Advertisement Posted June 29, 2022 Posted June 29, 2022 Hi Mikko Kankainen, Take a look here Voigtländer 15mm L39 (first version) with Leica M11 . I'm sure you'll find what you were looking for!
lct Posted June 29, 2022 Share #2 Posted June 29, 2022 Sony BSI sensors are not prone to purple corners generally and that of the M11 does not make exception. Same with the Heliar 15/4.5 v2 BTW. Link to post Share on other sites More sharing options...
lct Posted June 29, 2022 Share #3 Posted June 29, 2022 Topic says M11. Link to post Share on other sites More sharing options...
rramesh Posted June 30, 2022 Share #4 Posted June 30, 2022 I think the issue was highlighted with the M9. Link to post Share on other sites More sharing options...
hmzimelka Posted June 30, 2022 Share #5 Posted June 30, 2022 10 hours ago, Mikko Kankainen said: I tried to search but couldn't find another post. I bought for 200€ Voigtländer 15mm L39 version that is suppose to give purple corners with digital cameras. I thought that if this in indeed the case I will use it with my M4. However this lens performs great, no purple corners, just vignetting that is easy to correct, I use Voightlander 15mm II profile in Lightroom. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Excellent news. Did you use an in camera lens profile for this? Link to post Share on other sites More sharing options...
Mikko Kankainen Posted June 30, 2022 Author Share #6 Posted June 30, 2022 Yes I did but I shoot DNG. I used 16-18-21 @16 wich was the only close enough that I found. I didn't see any difference with this correction. If I remember right there was reports about purple corners from people using M8-M10. I had 240 before and har these corners with Voightländer 21mm f4 but those are also gone now. 1 Link to post Share on other sites More sharing options...
adan Posted June 30, 2022 Share #7 Posted June 30, 2022 Advertisement (gone after registration) 9 hours ago, Al Brown said: I have zero purple corners with my 12/5.6 Voigtlander on M10-R. Different optical design. The 12mm always produced less color vignetting (aka "Italian Flag;" "purple corners") than the 15mm v1/2. Even on the M9. Not perfect, but better. And Leica has been slowly improving the response with each FF sensor generation (M9, M240, M10, M10-R, and M11 (BSI)). 2 Link to post Share on other sites More sharing options...
hmzimelka Posted June 30, 2022 Share #8 Posted June 30, 2022 15 minutes ago, Mikko Kankainen said: Yes I did but I shoot DNG. I used 16-18-21 @16 wich was the only close enough that I found. I didn't see any difference with this correction. If I remember right there was reports about purple corners from people using M8-M10. I had 240 before and har these corners with Voightländer 21mm f4 but those are also gone now. So you also shot this lens uncoded and it didn't shade? Link to post Share on other sites More sharing options...
Mikko Kankainen Posted June 30, 2022 Author Share #9 Posted June 30, 2022 (edited) 8 minutes ago, hmzimelka said: So you also shot this lens uncoded and it didn't shade? Yes I did and I saw no difference. In Lightroom I chose lens profile as I mentioned. There is quite a lot vignetting but it's black not colored so it's pretty nice even without correction in some scenes and it's easy to correct at least when using low ISOs. Here is first test shot when I opened the package and tried the lens uncoded, no difference. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited June 30, 2022 by Mikko Kankainen Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/334012-voigtl%C3%A4nder-15mm-l39-first-version-with-leica-m11/?do=findComment&comment=4462320'>More sharing options...
Mikko Kankainen Posted June 30, 2022 Author Share #10 Posted June 30, 2022 (edited) This might be even better buy than version III because this is so light and this one can focus down to 0.3 meters, sample picture. For 200€ it's a bargain and it's great in film too. No rangefinder focusing with this one (L39) but usually not needed and close focusing using liveview. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited June 30, 2022 by Mikko Kankainen 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/334012-voigtl%C3%A4nder-15mm-l39-first-version-with-leica-m11/?do=findComment&comment=4462324'>More sharing options...
hmzimelka Posted June 30, 2022 Share #11 Posted June 30, 2022 13 minutes ago, Mikko Kankainen said: This might be even better buy than version III because this is so light and this one can focus down to 0.3 meters, sample picture. For 200€ it's a bargain and it's great in film too. No rangefinder focusing with this one (L39) but usually not needed and close focusing using liveview. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Cool, thank you! Link to post Share on other sites More sharing options...
lct Posted June 30, 2022 Share #12 Posted June 30, 2022 As far as M lenses are concerned, the CV Heliar 15/4.5 v2 is RF coupled but its MFD is only 0.5m. Doesn't suffer from color shifts on the M11 and doesn't need lens profiles either. Here at f/4.5 with moderate vignetting correction. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 6 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/334012-voigtl%C3%A4nder-15mm-l39-first-version-with-leica-m11/?do=findComment&comment=4462554'>More sharing options...
MissMikki Posted February 13, 2023 Share #13 Posted February 13, 2023 Thank you for this information! I just got an M11 and am glad the purple banding is not an issue. I was tempted to sell my ltm 15mm but now I won’t. Link to post Share on other sites More sharing options...
ChrisGA Posted March 19, 2023 Share #14 Posted March 19, 2023 This is the result from a Version I on a SL2S with chinese ltm-m-Adapter and a original m-l-Adapter: DNG: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! and with some Adjustments in Lightroom: absolutely no magenta-Problems…. Here the Setup….really funny is the handling…(-; 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! and with some Adjustments in Lightroom: absolutely no magenta-Problems…. Here the Setup….really funny is the handling…(-; ' data-webShareUrl='https://www.l-camera-forum.com/topic/334012-voigtl%C3%A4nder-15mm-l39-first-version-with-leica-m11/?do=findComment&comment=4729539'>More sharing options...
ChrisGA Posted March 19, 2023 Share #15 Posted March 19, 2023 Off course in bw also no problems…..(-; Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/334012-voigtl%C3%A4nder-15mm-l39-first-version-with-leica-m11/?do=findComment&comment=4729542'>More sharing options...
qqphot Posted March 19, 2023 Share #16 Posted March 19, 2023 Given the construction I expected much worse (smearing in the corners, etc) with this lens, but on my sony R bodies it looks much better than I thought it would. Of course on film it's great, too. The huge dynamic range of the digital sensor means the falloff is less of an impediment than on film, too. Link to post Share on other sites More sharing options...
