Are there different sizes then? In my experience virtually all flashes (at least post-WWII) fit on virtually all cameras - except for the different electronic systems and electric connections. Leica uses two configurations - one for the Panaleicas and one for the "true" (in no way. meant negatively) Leicas, like M, L,Q,CL,TL and SL series.
That is a tolerance problem. I too had to take a file to a flash shoe from time to time or shim a hot shoe with a piece of paper. Sloppy manufacturing. But for Leica cameras Theo should not be any issue across the range b
  • andybarton changed the title to Q and SL hotshot sizes
  • 2 weeks later...
On 6/7/2022 at 5:53 PM, jpjoycestudios said:
Does the Leica Q and the SL2 use the same size hot shoe?
What is the reason for your question? Are you looking for the proper Hot Shoe cover? If so, the one for the Q fits perfectly and are available at Leica Store Miami and B+H Photo.
It is also possible that others may fit as well
