J S H Posted December 4, 2023 Share #61 Posted December 4, 2023 (edited) Advertisement (gone after registration) 1 hour ago, marchyman said: Hours? I know it can take a while doing a low level format but hours seems a bit excessive. I'd suspect a bad card. They do go bad once on a while. I've probably thrown 2 or 3 away in the last 10 years. The low level format/overwrite option can sometimes take forever. However, it is worth the wait if you are trying to figure out whether the card has any issues. The normal quick format option is very fast. Edited December 4, 2023 by J S H Clarified description 2 Link to post Share on other sites More sharing options...
Advertisement Posted December 4, 2023 Posted December 4, 2023 Hi J S H, Take a look here M11 and SD card issue . I'm sure you'll find what you were looking for!
Jan Y Posted December 4, 2023 Share #62 Posted December 4, 2023 2 hours ago, J S H said: The low level format/overwrite option can sometimes take forever. However, it is worth the wait if you are trying to figure out whether the card has any issues. The normal quick format option is very fast. I finally worked out that the program stalled as my PC hibernated - all finished. I have not had a chance to evaluate whether the formatting solved my lock up issue. Link to post Share on other sites More sharing options...
LeicaR10 Posted December 6, 2023 Share #63 Posted December 6, 2023 Jan Y, I sent you a PM to help you. r/ Mark 1 Link to post Share on other sites More sharing options...
lct Posted December 6, 2023 Share #64 Posted December 6, 2023 On 12/4/2023 at 9:44 PM, J S H said: The normal quick format option is very fast. +1. I must have used the overwrite option a couple of times in 10+ years. My usual trick is to use the quick format to begin with and see if it works. It does generally if i judge by my lack of freezes but it's just empirical. 1 Link to post Share on other sites More sharing options...
