Match Technical - Soft Release - Boop - Compatibility to M11?
Hi all,
I have applied the Match Technical Boop Soft Release to my M11 and was wondering (afterwards), whether there might be any issues with the compatibility to the latest M11 shutter? Want to avoid any damage if the shutter might have changed in the M11 as there are different versions with a short and long post available!
Any idea?
Thank you!
Cheers,
Julian
vor 4 Minuten schrieb scott kirkpatrick:
I have a soft release from my stock in the M11.  It was purchased for use with  M10 or M9, and it works fine.  Threads are correct, and shutter button operation is just as usual.
Do you have the one with the short or long stem?
Overall, mine seems to work with the M11 as well but don't know whether anything could break if the shutter is actually not supported...
I have had problems with soft releases getting caught on a cord (not sure) and bending the internal stem of the shutter release (and it happened at a wedding shoot). So I went with this awesome soft release.
