After getting of last version of sensor, cover glass my M-E 220 started to do the same as many modern cameras seems to do with outdoor colors.
Just way too cold comparing to how I was seeing it.
Tried in LR, not so good. Using DNG, but no luck to find adjustments which will take away this blue cast without side effects.
Is here any successful ways to get warmer colors SOOC?
I have tried dial-in temperature in WB, but not sure which number I have to put.
Would IR cut filter helps to get rid of cold colors shifts or is where any other on lens filters to make it looks as it should on golden hour, instead of all day blue?
In LR under "Development" you should have a tweezer to set to neutral color somewhere. The tweezer is in the workbench at the right side and there at the top left.
Or as wizard writes, modify the temperature, but then still somewhat higher.
In the film age one would try a yellow filter. I have an R lens with built-in (not changeable🤨) daylight and artificial light filters.
Not sure what do you mean by tweezer. In LR where are two sliders for color and one eyedropper. I'm not good with sliders and almost never used eyedropper. Maybe I should give it a try, if I could get not blueish outdoors WB SOOC?
My M9 generally renders cooler than my m10
M9 in-camera WB isn't the best IMHO... (correcting from a whibal card in RAW under midday light sometimes makes 6500-7000k)
In LR/ACR I've noticed that the 'embedded' profile often renders cooler than the adobe standard one
But as suggested above, dialling in a high K number might help (and at least all the DNGs will have the same temp if you need to make adjustments later)
You could also try a split tone adjustment in LR
something around this
   crs:SplitToningHighlightHue="17"
   crs:SplitToningHighlightSaturation="2"
should be ballpark(ish)
If you haven't already you could try profiling your camera
Finally you could play with the camera calibration sliders in LR, negative green hue slider values is more yellow and red + saturation will make it warmer (M9 is quite red enough IMO, but it might work for you)
Just eyeballing it on the WB slider isn't a bad approach either! (I'm not joking)
Edited by Adam Bonn
I mean with tweezer the thing just under the word "Behandlung. I can choose the snow, the tree or the green leave to be gray.
But I work with LR CS6, so perhaps in your version it could be different. Sorry, it is an eyedropper.
Edited by jankap
Try using "CLOUDY" or "SHADE" for in-camera white balance, even in sunlight, if you are shooting jpegs. Those are basically "electronic 81A filters" of slightly different intensities and tints. But wizard's hint will be similar, and more flexible.
For jankap - that tool symbol has been known as an "eyedropper" for 25 years or more, since it "takes a sample" of the image, for a number of uses, depending on context. ;)
https://www.discountvials.com/dropper-assembly-24-400-closure-7-x-108-mm/?sku=DR24400108-X-KDR-64&gclid=EAIaIQobChMIssXGl-T_9gIViWxvBB1GrglkEAQYBSABEgIptvD_BwE
Edited by adan
Standard profile on left, one I just made you on the right. No worries if you don't like it.
1 hour ago, Adam Bonn said:
Try this. Quick and dirty profile that should be a little warmer... maybe you like it, maybe not. (Hard to profile creatively for someone else, plus I prefer cool images so harder to guess)
(It's single illuminant)
Sorry, my LR is 6.0. I don't think it could import preset.
I have tried today, cloudy seems to give better results if sun is present. But what to do if it is cloudy for real?
it's not a preset it's a profile, that's compatible with all LR/ACR versions
If you want the convenience of in-camera WB, then I think you should just make a point of adding (say) approx +500k on the WB slider to whatever WB comes out of the camera.
Seriously, it's WB.. on the one hand it's precise measurement of the temperature of the light, but in another far more in real life way it's actually whatever you think looks good in the photo, just drag the WB slider towards yellow until it looks like crap, then back it off until doesn't. It's like 10 secs of work. Do it at the end because contrast/shadow adjustment changes the look of colours
Your other options involve moving house somewhere much further south 😅
Your camera has a new cover glass. Your pictures are somewhat blue. That means, that the cover glass acts as a blue filter.
So you should generally set the camera to "somewhat less blue", that is the setting "cloudy". These things are very primitive. So set you camera to "cloudy".
If it is cloudy your pictures will be too blue, because the setting "very cloudy" fails. Then you correct that in LR. Somewhat higher temperature. Nothing special, trust us; cameras are dumb.
Try the vibrance slider.
That is obsolete, I fear. Postprocessing has come a long way since 2015. But you can save a preset as default, as you can import camera profiles. So your best option would be to get a ColorChecker Passport and create a camera profile using the Xrite software (free) Dead easy and a few minutes work.
CCP came as part of award I got from international competition. But for some reason I didn't find using of LR and its own software easy.
