Franka373 Posted April 5, 2022 Share #1 Posted April 5, 2022 Advertisement (gone after registration) I have this lens and the M11. Although I have used M cameras for 17 years it’s a first for the 135. I feel like I am getting back focus using the rangefinder. I have tried it at 7 & 23 feet. At 7 feet it is off a little over an inch. At 23 feet it’s a little more. I got concerned when I first used it at infinity and it was not in focus. I was outside with a fast shutter speed up around 2000. With the new visoflex I can get good focus. The focus thrown on the lens is surprisingly short. I wonder if that has an affect? I have checked my 28 summicron and 50 summilux asph and those seem fine. My question is could it be the rangefinder, the lens or both? Thanks for you help. Link to post Share on other sites More sharing options...
Advertisement Posted April 5, 2022 Posted April 5, 2022 Hi Franka373, Take a look here 135 APO question. I'm sure you'll find what you were looking for!
stephan54 Posted April 5, 2022 Share #2 Posted April 5, 2022 (edited) My Summicron 28 and Summilux 50 focus also accurately. The Apo 135 focusses accurately at infinity but I do see some misfocus as the object a meter behind where I focussed is sharp. Does mainly happen when pointing the lens up or down. Edited April 5, 2022 by stephan54 Link to post Share on other sites More sharing options...
Franka373 Posted April 5, 2022 Author Share #3 Posted April 5, 2022 When I focused at infinity for a landscape it was parallel to the ground. When I did my test it was at a target with inch markings at about a 45 degree angle down. Link to post Share on other sites More sharing options...
spydrxx Posted April 5, 2022 Share #4 Posted April 5, 2022 It sounds like you may need to get it properly calibrated. Link to post Share on other sites More sharing options...
charlesphoto99 Posted April 5, 2022 Share #5 Posted April 5, 2022 I use a 135 APO often with my M10-R. It can be a finicky lens for closer precise focus with the rf - mine is off probably 1/4 inch at closer distances but that's within tolerance and typically will be covered up if using f5.6 and above. I mainly use mine at infinity for landscapes and there it should be razor sharp at all apertures. So it sounds like your lens needs a calibration. Had this happen with my 75mm APO. Link to post Share on other sites More sharing options...
Jeff S Posted April 5, 2022 Share #6 Posted April 5, 2022 Have Don Goldberg (DAG Camera) check it out. Jeff Link to post Share on other sites More sharing options...
Franka373 Posted April 6, 2022 Author Share #7 Posted April 6, 2022 (edited) Advertisement (gone after registration) Thanks for the help. What irks me is that it is a new lens. I’ll check DAG. Edited April 6, 2022 by Franka373 Link to post Share on other sites More sharing options...
Jeff S Posted April 6, 2022 Share #8 Posted April 6, 2022 (edited) Call him first to briefly discuss issue and, if deemed appropriate, timing of service. I recommend him over Leica NJ, despite warranty coverage, as he does excellent work for very reasonable cost and generally fast turnaround, schedule permitting. There are many corroborating discussions. Jeff Edited April 6, 2022 by Jeff S Link to post Share on other sites More sharing options...
overexposed Posted April 6, 2022 Share #9 Posted April 6, 2022 i also use the lens on my m10m and m10r, and yes via RF it is difficult to acquire critical focus, but once this is achieved, its a great lens Link to post Share on other sites More sharing options...
Maarten Posted April 7, 2022 Share #10 Posted April 7, 2022 Using the RF you might notice focusing is more precise when starting from infinity and stop turning the focusing ring once you've reached focus. Use your body to fine tune when needed. On my M10 i can get perfect focus with my 135mm Tele-Elmar this way. 2 Link to post Share on other sites More sharing options...
