Hi
I recently dislocated my right shoulder and will probably need surgery in the next week or two; and then I'll need a sling and then rehab. Wondering if there are any options for shooting the SL2 left handed that anyone has used successfully ? I was thinking the handgrip adapter might be an option, but it doesn't look like there's a release button on the left hand side. I'm not sure how comfortable I'm going to be holding the SL2 and a long lens anyway (and manual focus is going to tough unless I use zone focusing), but hoping I don't need to spend the next 2 or 3 months camera-less.
Any suggestions would be great; thanks in advance !
Other than the SL2, if you do a web search for “Left-Handed  Camera - The Online Photographer”, you’ll get a 2018 article and discussion.  Read the comments that follow, including reader ideas. Most common response… the old Exactas.
In the modern age, a smartphone might be a good solution; often configurable controls, as well as light and compact.
Jeff
Edited by Jeff S
One thought is to get a camera cage and a remote trigger shooting it like a video rig. That said, even if you are using your left hand, a heavy camera will still activate muscles that will cause you pain on your right shoulder as you try to maintain balance. You’re better off using a smartphone and let your body heal properly.
Edited by beewee
The obvious suggestion is to use a tripod for the camera and either a cable release or the Fotos app on your phone.
I hope your shoulder gets better soon.  If you have to have operation, remember to ask the doctors what you can expect to find afterwards.  They re all really keen at describing teh surgery and what they do, but often less aware that what the patient wants to know is what happens afterwards, and how much time off work they'll need.
Good luck!
He,
If handheld I would use a remote ands pole attached to the camera.
or a pistol grip
or top rig
but it will take a while until you feel comfortable.
if there is a good camera store nearby , I would go there and test different set ups.
kind regards
