I occasionally use the half cases on my M10R and M10M. The version where you have to take the case off to change the battery or SD card.
Any prior M10 users with the Arte di Mano case try the old case on the M11. I don’t want to buy the new M11 versions if I don’t have to. (Still waiting for my M11). Don’t need to change battery or SD card on an outing.
Maybe one little thing: The screen is a bit different on the 2 cameras. When you are very particular about such details then it might upset you. As I do not need the LCD a lot its fine for me. Try it out. You still can decide if for you it works or it does not work well enough.
I picture might tell more than 1000 words.... ☺️
M10 Arte di Mano (with battery access door) on a M11.
  • The screw is in a different position
  • All buttons and the back screen are still nicely accessible
  • I have 2 Arte di Mano cases.  One for my M10 and one for an M10M.  I noticed that without the screw one of the two perfectly fits the M11 the other one is a bit loose and I imagine it could come off the camera when it is hanging on your shoulder
  • Battery access door is of course unusable
So for occasional use AND if you have a tight case then it might work well.
Edited by Stef63
  • Thanks 2
Thanks so much.  My AdM cases do not have screws but has the short leather curved straps on both sides that "lock" the camera strap in place so it should work just as well on the M10 series.
