Hi All,
  I have several Leica M lenses being used on M8.2 and M9 bodies. My only 6 Bit coded lens is Elmarit 28 Asph. If I switch the camera to manual and select the lens being used on the camera does it achieve the same result as a lens with 6 bit coding? These are not real old lenses just ones made previous to digital bodies
.Thanks, Smitty
Just now, smitty's said:
Hi All,
.Thanks, Smitty
Selection in the menu has the same effect as 6 bit code. The caveat to that is the newer lenses having 6 bit codes since their beginning are not in the menu.
9 minutes ago, antigallican said:
Thanks. I only have the M9.
Sorry John,
I was not clear,
my post is for @smitty's post #1
M8-2 and M9 bodies.
2 hours ago, smitty's said:
Hi All,
.Thanks, Smitty
17 hours ago, a.noctilux said:
Sorry John,
I was not clear,
M8-2 and M9 bodies.
Thanks. If I hadn’t had the info and been new to these cameras the information would have been very welcome -  and it may still be to people casually browsing
