DYMO: Ultimate 6-bit coding solution!
ArtZ
I went out and bought a DYMO label maker to test this out. My CV lenses, both M-mount and screw mount with an adapter, cannot use a DYMO label as the tolerance is too tight- I cannot fully rotate the lens on my M8 to lock the lens in. Too bad, it would be a great solution for me.
Hi Lloyd,
Why not use the LT-M8 adapters for the LTM lenses? They're the ticket and worth the $$.
Cheers,
Sean
  • Replies 57
  • Created
  • Last Reply
Guys,
I've been out for a couple of days. I have seen your comments.
The reason I found for not having problems with the Nokton is probably because the bayonet ring has a smaller diameter (4mm) than Leica lenses. When the lens is attached to my body, I can see the mount ring on my M8. I believe this gives extra tolerance.
I've intensivly using my Nokton these days. It really works perfect. I'm sorry that not everybody can do that.
Though, when my CON 28/2 will be back from Solms, I will probably send the bayonet ring to John Millich for hard coding.
Regards,
Wilson,
I have a problem with the Elmarit 2.8/135mm - coded exactly the same, it does activate the 90mm frame automatically, but focal length is not displayed. Mount was also milled by John Milich, but there is a screw in the 001001 (both white) position; maybe that is the problem?
Best,
Jan
Did you cover the screw in white paint completely? It should work then.
Does the M8 give indication that it is able to identify the lens other than having to shoot a frame and checking the EXIF data off the card? Is there some confirmation in the menu screens that the coding has been successful?
  • 1 month later...
I'm bumping this one since I would like to try this on my Leica lenses.
I've been manually drawing the stripes with a pen, working great on the 35mm, but my 50mm has clearly a mind of it's own, since I'm not able to draw the lines good enough...
Andreas,
I have my Nokton 35/1.2 coded like this and works really well. My TE 28-35-50 was also coded with the Dymo until last Friday (I got it properly coded at Solms) and it worked perfectly well.
The Leica guy who coded my TE was surprised (and pleased) to see it. The reason why I took my TE to Leica's CS it was because I could fit the lens with no problem in the first body. On the other body,it was very difficult to insert the bayonet ring (independently of the Dymo tape). After Leica replaced the bayonet ring, there's still a problem: If I screw completely the lens in this body, I get 4 frames at the same time in the viewfinder. I realized this when I was travelling from Solms to Paris. I believe the problem is on the M8.
TIPS:
1.- If you use the Dymo tape method as described previously, leave about 5mm at each end after a black mark. If you cut the tape too short, the black marks will be dammaged after a while.
2.- After coding your lenses, check during the first weeks if some excess of adesive oozes from the tape (and if necessary clean it with a cloth). This is normal because the thickness of the adesive on a Dymo tape is thicker than the tape itself. After a couple of weeks, this is gone.
Andreas,
TIPS:
OK, thank you for the tip, and for inventing this way of self-coding! It will save us some money and time having the lenses at home instead of at Solms :D
I tried with a Brother machine, but I could not get it to work. (I'm suspecting more and more my sensor to be broken)
In Finland Dymo labelpoint 150 and 250 are available. The Labelpoint 200 seems to be an obsolete model?
DYMO | Toimistokäyttö
DYMO | Product Compare Results
I believe both of them should work fine.
If you want, when I return from NYC at the end of this week, I can send you by mail a couple of Dymo stickers for your lens if you want to try first. Let me know. If you want to try, just tell me what lens you want to code and I'll send it for you.
Cheers
  • 3 weeks later...
I finally bought a DYMO machine, and it's simply impossible to get the coding to work...
Tried atleast 50 times, and no way...
By holding the dymo tape with my fingers aligned to the sensor I have managed to get the sensor to recognize the lens, but when placed on the lens it's impossible :(
I think I need a picture of a lens with the coding exactly straight.
Any helpers?
I've never been able to successfully hand code a lens either with the DYMO or Sharpie methods.
Even using a factory coded lens as a model doesn't get it done.
When all other sources of frustration in my life have disappeared I may try again.
Sorry, I didn´t suceed too. The M8 won´t accept my Elmar135 nor the vc 28. Maybe it´s a prob of my brother P-touch. The cam only accept the coded 50Lux. I finished trying.
lg
Dieter
For me both work perfectly well. Here is the CV28:
No, still no joy with the lenses.
Funny though, no problem coding one of our triplets...
  • 2 weeks later...
