Are there more established brands out there of DSLR - film scanning equipment?
negative.supply
the name of this website and of the company I heard yesterday for the first time.
I find some of the articles on offer interesting, but I wish the descriptions of each item and of the combinations was more detailed.
Any experience with other similar products?
Edited by tri
Yes, there are:
Which product by negative supply is it that you want to know more of? The film carrier was crowdfunded in Kickstarter ( http://kck.st/301j2ta ). If you have any questions about that, I might be able to help. BTW, negative supply is now developing a light meter.
I found the 'film carrier' by negative supply quite useful for copying strips or even rolls of film, as it copes quite well with even a strong curl. A copy stand is mandatory, I think. I can't remember whether it can be used with a BEOON, but I think that's a bit doubtful.
negative.supply
Essential Film Holder (clifforth.co.uk)
I purchased various items from Negative Supply and it’s an excellent quality.
Can it be cheaper, yes, but IMHO, these things lasts forever and few hundred bucks won’t make a difference on a long term.
If you don’t need or want top notch quality and scan films once in a while, there are cheaper options mentioned above.
Our house is small with no place for a traditional darkroom, including the one bathroom that has a skylight, so I have tried various methods of scanning. The Plustek 7600i was a fine scanner. It gave good results and I even learned to live with Silverfast but to scan a roll of film would take better part of an afternoon. I looked at the Epson bed scanners but they took up too much of the limited space I had available. Then I tried camera scanning. I started with my spouses Sony A6000, an adapted Voigtlander 50 2.0 Collapsable Heilar, a cheap light pad and some holders from the Plustek. Next was a beater A5100 with a 55 2.8 Micro-Nikkor AiS, Lomography DigitLIZA, a Alzo copy stand and a better light pad. This worked pretty well until I found a brand new Sony A7II for a good price. Next up was the addition of a Skier Copybox. This is a combination light source and negative holder in s nicely made bamboo box. The 135 holder was reversible for mounted slides and the medium format was adjustable for 6x4.5 to 6x9. It worked well as was giving me mostly good results, then I discovered the Alzo copy stand was not holding the camera parallel to the base. Made some changes by then decided to move up to the Negative Supply Pro Riser II. It holds the camera securely and is easy to adjust. All was good up to the point where the light source in the Skier would cut out at various times. Gave away the Skier Copy Box, bought the Negative Supply Carrier MK I adding the 5x7 Lightsource Pro 95 CRI. The last change was to move from the manual focus Micro-Nikkor to the Sony FE90 2.8 Macro. It took a while but I can scan a roll in minutes and the camera is the only piece that would ever need an upgrade.
25 minutes ago, tri said:
Do you have a traditional film scanner, too?
Many thanks for the link :) It includes a free tutorial in a nutshell from an honest expert.
  • 3 years later...
