[Maybe I am the only one who has not yet updated his CL to the latest firmware, in which case this post may not be relevant to anyone :).]
Leica has apparently updated their website and now the CL firmware downloads are not easy to find. Google search results contain broken links to Leica's site. I have contacted Leica about problems with their website.
In the meantime, you can find the firmware here:
https://leica-camera.com/en/photography/cameras/cl-tl/cl-black/firmware
The downloaded firmware file has incorrect name (pm-53973-CL___41_.lfu). You must rename it to CL___41_.lfu before copying it to the SD card.
P.S.: Note that the firmware downloads page for the silver CL does not contain the latest firmware.
5 minutes ago, jaapv said:
Hmm - I clicked photography --> CL/TL system --> Leica CL --> Firmware and there it was... You need to use the links in the white pulldown.
Can you post the link? Isn't it the same link that I posted:
Photography>CL/TL System>Overview>Leica CL(black)>Firmware> 4.1 firmware available, but wrong name; no 4.1 firmware under <silver> selection.
No firmware available under registered product downloads, nor under Services>Support>Downloads>Leica CL/TL2 Systems
this page is a real mess
and there is no firmware option in "topic" if you select the camera system first, if you leave the "category" and "subcategory" on ALL/ANY, then it shows firmware zip/exe, and firmware in the "topic" section..
Edited by frame-it
