Leica 12008, 12012 finders (21mm) - construction?
Yesterday I received a secondhand 12008 finder (21mm plastic) from a reputable Leica dealer.
I noticed some dust inside - and also noticed that the housing was slightly separated (you could see the tiniest sliver of the side of an optical element. I separated it slightly more with my thumbnail, blew the dust out of it with canned air, and pressed the two halves back together - and they are now holding tight.
Are these finders just held together with a friction fit? I'm guessing someone cleaned this item at some point and did not completely close the case.
Thanks!
Dante
x
32 minutes ago, 250swb said:
They aren't very well made but after cleaning it out and snapping it shut it may never happen again.
I imagine it won't, especially after reading that the front element is glued all around. It was just weird. And I agree, they are absurdly built for the price (though I got one for not much more than a 21mm CV version).
Dante
Thanks!
Dante
Marco cavina loves the 21mm elmarit-m but he is very critical of this viewfinder,he basically says that although its expensive it is poor quality both in build and optics.
That's been the assessment of 100% of people who have used it... and the metal predecessor was pretty bad too. The real point of this finder is that it is small. Its mustache distortion also makes it easier to align the camera parallel with the subject.
I am waiting on a Zeiss 21mm finder, but the current leader in terms of usability is the Konica VL-3, from the 21-35 Hexanon. It's like a 21mm CV on steroids, offset, with 21mm and 35mm framelines. The problem is that said finder is irreplaceable if lost or damaged.
Dante
Dante
One thing that irritates me with leica is that they make beautiful but expensive cameras and lenses but also crappy olympus copy EVF's and plastic viewfinders and just plain ordinary batteries but charge the customer very high price for both the quality products and the total crap or ordinary ones!
Yes, but they have the "Leica" logotype, that adds 200%. LOLOL...
