Hi,  I am new here and do not have a Leica.
I am trying to figure out what the various codes means for the m system lenses.  Some are 3 digits long; others 5 digits.  e.g. Summilux 35 1.4 Asph FLE (121), number 11663
.. and I only see 3 digits used for the older lenses, like the 1960s Summilux I 35 1.4 pre-Asph  (036)
Thanks for your help on understanding the above.
I am interested in the M system for the character, esp. of the old lenses.  My plan is to wait and see what the M11 body is like.  If it is a big increment (for me) over the M10, I'd buy it.  If not, I'd buy a used M10.
I started out with Olympus OM system, then switched to the Nikon system in the mid or late 1970s.
I currently use a few Panasonic m43 bodies nearly always with the Pana-Leica lens.  I kept my F3 and FM and some old "character" type Nikkors, and also use a hassy 501 some for film.
Hello Ralf,
Welcome to the Forum.
I do not know what the 3 number codes in parentheses mean, such as the (036) you asked about.
The 5 number codes such as 11663 that you asked about are the current coding system for identifying Leica products.
Originally Leitz used a system that was 5 letters such as PLOOT. which is the code letter system for a device to add to the camera for using telephoto & closeup lenses.
Leitz is the predecessor Company to the current Company Leica.
The bodies, since around 1959/1960 usually begin with 10 and then this is followed by 3 other numbers.
The lenses, also beginning 1959/1960 usually begin with 11 and then this is followed by 3 other numbers.
Sometimes there are model number changes for small differences between earlier & later lenses, etc. Sometimes there are significant changes between earlier & later lenses with no change in model number.
Leica, along with the predecessor Company Leitz, have exceptions to many systems of numbers, etc.
For example there is a lens that has the code number 98000.
Welcome, also, to the World of Leitz/Leica.
Best Regards,
Michael
Edited by Michael Geschlecht
