rsolomon Posted June 23, 2021 Share #1 Posted June 23, 2021 Advertisement (gone after registration) I’m currently an M240 user with 21 SEM , 35 Cron , 75 Cron. I’m considering acquiring a CL , especially if the CL-2 comes out. I feel this gives me the option of L lenses with all their benefits as well as my M lenses and their fun and benefits. Can anyone speak to the M experience on the CL? ….and with the lenses mentioned above thx in advance Link to post Share on other sites More sharing options...
Advertisement Posted June 23, 2021 Posted June 23, 2021 Hi rsolomon, Take a look here CL and M lens experiences. I'm sure you'll find what you were looking for!
M.piras Posted June 23, 2021 Share #2 Posted June 23, 2021 Hi, i think you can find a lot of CL+M experienced spread on the forum, also CL is a perfect completion to the owner of M. I use them both regularly and can assure it’s like water & wine, you must taste both to appreciate the other one (even off sometimes need more and more and more sips to be sure….) 2 Link to post Share on other sites More sharing options...
jaapv Posted June 23, 2021 Share #3 Posted June 23, 2021 2 Link to post Share on other sites More sharing options...
Ray Vonn Posted June 23, 2021 Share #4 Posted June 23, 2021 1 hour ago, rsolomon said: I’m currently an M240 user with 21 SEM , 35 Cron , 75 Cron. I’m considering acquiring a CL , especially if the CL-2 comes out. I feel this gives me the option of L lenses with all their benefits as well as my M lenses and their fun and benefits. Can anyone speak to the M experience on the CL? ….and with the lenses mentioned above thx in advance @jaapv kindly referred you to a thread I started in much the same spirit. My views seem to align with yours. I mean people talk of the transition from M to CL as almost seamless, but it surely can’t be that straightforward right? (No RF patch etc). That thread gives some good evidence in terms of image output. 1 Link to post Share on other sites More sharing options...
wda Posted June 24, 2021 Share #5 Posted June 24, 2021 Focusing on the CL with M-lenses is a new and positive experience. As you would expect, each lens handles differently, but positively. In fact, I find it quicker and more accurate to focus my M lenses on my CL than I do on a rangefinder body, which can quickly go out of alignment if mishandled. Magnification and focus peaking are great aids. 3 Link to post Share on other sites More sharing options...
rsolomon Posted June 24, 2021 Author Share #6 Posted June 24, 2021 Thx all. I suppose focus is similar to M240 with EVF-2 ? I do own and use for my 75 cron, truth for me is it increases my focus hit rate substantially. Link to post Share on other sites More sharing options...
Guest Posted June 24, 2021 Share #7 Posted June 24, 2021 (edited) Advertisement (gone after registration) 13 hours ago, Ray Vonn said: I mean people talk of the transition from M to CL as almost seamless, but it surely can’t be that straightforward right? (No RF patch etc). It really is straightforward. I change between M10 and CL all the time (both with M lenses). No problem. Edited June 24, 2021 by Studienkamera Link to post Share on other sites More sharing options...
lct Posted June 24, 2021 Share #8 Posted June 24, 2021 2 hours ago, rsolomon said: I suppose focus is similar to M240 with EVF-2 ? Not exactly. The focus point can move on the CL but turning aperture rings cannot trigger auto image magnification. Otherwise the CL's EVF is much more responsive than the EVF-2. 1 Link to post Share on other sites More sharing options...
ramarren Posted June 26, 2021 Share #9 Posted June 26, 2021 (edited) On 6/24/2021 at 2:12 AM, wda said: Focusing on the CL with M-lenses is a new and positive experience. As you would expect, each lens handles differently, but positively. In fact, I find it quicker and more accurate to focus my M lenses on my CL than I do on a rangefinder body, which can quickly go out of alignment if mishandled. Magnification and focus peaking are great aids. On 6/24/2021 at 3:45 AM, rsolomon said: Thx all. I suppose focus is similar to M240 with EVF-2 ? I do own and use for my 75 cron, truth for me is it increases my focus hit rate substantially. I've been working the the CL body with only R and M mount lenses since 2018. I had/have M cameras since the early 1970s. Using the CL with an M or R lens is essentially like using an SLR: You focus the lens based upon image sharpness in the viewfinder, not based upon aligning a rangefinder. It goes beyond the SLR in that you can easily apply magnification to assist in getting the focus right on the money, and you can use focus peaking help get to the right focus range very quickly. Unlike when using an SLR, you are always focusing at the taking aperture ... the plus of this is that you can see the resulting DoF very clearly, the negative of this is that it can make getting the critical focus a bit trickier in some cases since DoF can mask minor inaccuracies in focus discrimination. If you're going to use M lenses on the CL, it is most convenient to use the Leica M Adapter L instead of third party adapters. The M Adapter L is perhaps one of the most precisely made adapters, so the focus is right on the money according to the scale, and it triggers the body to use Leica's lens profiles correctly. Coded lenses are automatically selected correctly. It also tells the body to use the right dial for focus magnification, which is very convenient compared to using the keypad arrows. It's a good setup. The CL essentially replaced my digital Ms due to its versatility and excellent image quality. At all but the highest ISO settings, its sensor performance matched the M-P 240 and M-D 262 in my experience, and the body is just slightly smaller and a couple of ounces lighter as well. It gives me the TTL focusing I need for close up work and long telephoto work, the CL's EVF is better quality than the add-on EVF for the digital Ms. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Bird Feeder - Santa Clara 2021 Leica CL + Leica Summilux 35mm f/1.4 (1972 edition M-mount) ISO 100 @ f/2 @ 1/1000 sec G Edited June 26, 2021 by ramarren 6 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Bird Feeder - Santa Clara 2021 Leica CL + Leica Summilux 35mm f/1.4 (1972 edition M-mount) ISO 100 @ f/2 @ 1/1000 sec G ' data-webShareUrl='https://www.l-camera-forum.com/topic/322086-cl-and-m-lens-experiences/?do=findComment&comment=4226680'>More sharing options...
robgo2 Posted June 26, 2021 Share #10 Posted June 26, 2021 What ramarren said. I use two M-mount lenses on my CL (a Voigtlander Nokton 50 f1.2 and a Nokton 75 f1.5), and I am very satisfied with the performance of both. As mentioned, focusing is actually easier and more precise than on an M rangefinder camera. Of course on the CL's APS-C sensor, M lenses have an effective focal length 1.5 times greater than actual, but that can be used to advantage. 1 Link to post Share on other sites More sharing options...
jaapv Posted June 26, 2021 Share #11 Posted June 26, 2021 On 6/24/2021 at 12:03 AM, Ray Vonn said: people talk of the transition from M to CL as almost seamless, but it surely can’t be that straightforward right? However, it is.. On 6/24/2021 at 12:45 PM, rsolomon said: I suppose focus is similar to M240 with EVF-2 Far,far better. 1 Link to post Share on other sites More sharing options...
Gregm61 Posted June 30, 2021 Share #12 Posted June 30, 2021 On 6/23/2021 at 3:15 PM, rsolomon said: I’m currently an M240 user with 21 SEM , 35 Cron , 75 Cron. I’m considering acquiring a CL , especially if the CL-2 comes out. I feel this gives me the option of L lenses with all their benefits as well as my M lenses and their fun and benefits. Can anyone speak to the M experience on the CL? ….and with the lenses mentioned above thx in advance Those three fl’s plus the 135 APO are what I use with my M262 and I purchased the M adapter with my CL. It definitely works “well enough” but honestly, manual focusing with the TL lenses works much more efficiently and, there’s a reason why I don’t use a 50mm M lens with the M body and that’s what the 35/1.4 FLE lens becomes on the CL. Since my initial attempts with the CL and M lenses + adapter, I’ve left the M lenses for the M body and today own every TL lens Leica has made for the CL. Some days I may go out with the 11-23 and 55-135 only and sometimes nothing but the primes. Last week I did some horse photography using the M262 and 35/1.4 and (more) the CL with only the 55-135. Worked like a charm. The 55-135 is an awesome lens. 2 1 Link to post Share on other sites More sharing options...
jaapv Posted July 2, 2021 Share #13 Posted July 2, 2021 You probably missed the option of the magnification with the right wheel. 1 Link to post Share on other sites More sharing options...
pebbles Posted July 4, 2021 Share #14 Posted July 4, 2021 I found my 40mm Summicron worked fine on my CL but no better than the 18-56 I normally use. Where I have been surprised is in the quality of my pre-war lenses particularly the 50mm Summar and the 90mm Elmar. With contrast focussing I have been very pleased with the images. Link to post Share on other sites More sharing options...
Gregm61 Posted July 4, 2021 Share #15 Posted July 4, 2021 (edited) On 7/2/2021 at 9:37 AM, jaapv said: You probably missed the option of the magnification with the right wheel. No, I used that feature but the CL-dedicated lenses auto-magnifying in manual focus mode is way, way, WAY more convenient/fluid in practice. Edited July 4, 2021 by Gregm61 Link to post Share on other sites More sharing options...
didier Posted July 4, 2021 Share #16 Posted July 4, 2021 On 6/24/2021 at 11:12 AM, wda said: Focusing on the CL with M-lenses is a new and positive experience. As you would expect, each lens handles differently, but positively. In fact, I find it quicker and more accurate to focus my M lenses on my CL than I do on a rangefinder body, which can quickly go out of alignment if mishandled. Magnification and focus peaking are great aids. I agree on how easy and straightforward the focusing on CL/SL is with M Lenses. The focus magnifying works very well on the CL and allows for precise and quick focus. Please note it works best wide open : and the more you close down, the more it is difficult to focus accurately (because of more depth of field). A second thing I’d like to share, is that in bright sunlight, the EVF experience is far from the M OVF. The times I really really regret the OVF most is in high contrast situation, particularly bright sunlight. Didier 1 Link to post Share on other sites More sharing options...
Gregm61 Posted July 4, 2021 Share #17 Posted July 4, 2021 (edited) I finally resorted to turning the brightness of my CL’s EVF to the max. Auto never really worked for me in bright, contrasty daylight. Definitely cut battery life down but makes a difference for me…..and I have kept my digital M to a large extent because of the optical finder….and just purchased a new Nikon Df to use my manual focus AIS Nikkors. Edited July 4, 2021 by Gregm61 Link to post Share on other sites More sharing options...
ramarren Posted July 6, 2021 Share #18 Posted July 6, 2021 On 7/4/2021 at 10:06 AM, Gregm61 said: No, I used that feature but the CL-dedicated lenses auto-magnifying in manual focus mode is way, way, WAY more convenient/fluid in practice. Differences of opinion on that. I've had various cameras that did automagnification on focus and generally turned it off, it gets in my way. I want to turn on magnification when and if I want it ... only. Particularly with longer than normal lenses, it can be very jarring to see the whole scene blast away into something completely unrecognizable when I turn the focusing ring. G 3 Link to post Share on other sites More sharing options...
Gregm61 Posted July 6, 2021 Share #19 Posted July 6, 2021 (edited) Of course. That’s why the cameras allow you to use it or not, just like there are those who like using M lenses on their CL and there are others, like me, who don’t like their 21mm superwides changing to some not-so-fun and less than fast f3.4, 30-something mm semi-wide when used on the aps-c sensor and my favorite, almost $5,000 (at the time I bought it) 35mm f1.4 FLE turning into something (again, for me) far less than exciting to use. I’d rather have the 11-23 mounted on my CL that covers the primary fields of view I want and 99% or more of the time the question of manual focus, focus peaking and/or either auto or manually initiated magnified focus assist is completely irrelevant, but those few times I actually need it, manual focus with the CL lenses (again for me) is far more convenient. If this was an SL-2 my opinion would be different. Chances are I would be using my M lenses a lot, but it isn’t. Edited July 6, 2021 by Gregm61 Link to post Share on other sites More sharing options...
jaapv Posted July 6, 2021 Share #20 Posted July 6, 2021 26 minutes ago, Gregm61 said: 21mm superwides changing to some not-so-fun 30-something mm semi-wide when used on the aps-c sensor Not much of a problem. 21 is indeed decently wide, but I prefer 18 or less for that designation. So Voigtländer has 10, 12 and 15 mm offerings which perform spectacularly well on the CL -and on FF too-, take minimal space and weight in your camera bag and don't kill your wallet. 1 Link to post Share on other sites More sharing options...
